Question about Haier CWH18A Commercial Cool 18,000 BTU RAC Electronic Control Window AC Air Conditioner w/ 16,000 BTU Heater - R-104A Refrigerant, 4-way Air Flow, 3 Cool Setting, 3 Fan Setting, 24-Hour on/off Timer, Auto Restart, 208230 Volt. Covers 700 - 1,000 sq ft
Haier CWH18A heat does not work A/c seems to work fine
Why doesn't the heat work?
My washer will fill and wash but when it gets to the rinse and spin cycle than it just stops and wont draiain
gwt450aw mine was washing but was not spinning and was loud like many others have posted. Seems the electronic drive motor had washer type ring inside the middle of the motor that was wavey from heat guess if happens over time. The friction was over heating the motor till it would stop working. Took that part off works fine. Once you've inside you can tell there is no need for it. Given the position of the motor. FYI the drive motor is under 10 year warranty from haier with proof of purchase for the date.
/uploads/images/6_9_2014_9_24_19_pm.jpg
Feb 04, 2014 | Haier GWT450AW Washer
NEW REMOTE WILL NOT WORK IN HEAT MODE
maybe the new remote doesn-t have in operation mode the heat.
Dec 27, 2013 | Haier Heating & Cooling
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
Dec 18, 2011 | Haier Freezers
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My haier dryer quit. I replaced the thermostat located in back near the heating element and the thermal limiter. The dryer worked twice but seemed to get very hot. The on the third time it quit again. What...
Have you made sure the vent is not plugged, and that the vent fan is working properly? This would cause over heating. There is also a thermal fuse that caused it to quit again.
Sep 11, 2010 | Haier GDZ5-1 Electric Dryer
Haier HLP140e Dryer won't heat after circuit tripped
There may be more than one heating element or the heating element could be partially defective. Go to www.repairclinic.com and enter HLP140E. You will be presented with a list of common replacement parts and may be able to view a video showing disassembly of a generic Haier dryer (like the sound of that) and identification of parts.
May 29, 2009 | Haier HLP140E Electric Portable Dryer
Haier CWH18A Commercial Cool 18,000 BTU RAC Electronic Control Window AC Air Conditioner w/ 16,000 BTU Heater - R-104A Refrigerant, 4-way Air Flow, 3 Cool Setting, 3 Fan Setting, 24-Hour on/off Timer, Auto Restart, 208230 Volt. Covers 700 - 1,000 sq ft Logo
22 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
