Question about Crosley Refrigerators
How do you fix the defrost on crosley shelvodor ct15a2 refrigerator
Coil freezes up
  • 126 Answers
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Posted on Dec 14, 2007
SOURCE: GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Posted on Jun 25, 2008
  • 5 Answers
SOURCE: Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Posted on Aug 13, 2008
woodchuck789
  • 4070 Answers
SOURCE: Refrigerator freezer drains keeps freezing over, not plugged.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Jul 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
My Refrigerator freezer is not freezing or cold like it should be. The condenser coils are freezing up even after defrosting and cleaning. Can you help me?
Sounds like you're low on refrigerant. Very soon it will not cool at all unless you fix the leak and recharge. This is a professional job, not DIY.
Feb 13, 2015 | Refrigerators
Why water is leaking in freezer where cooling fins are
The defroster coil melts the frost build-up on the coils and the water hits the aluminum plate that guards the plastic drain from he heat of the defrost element, but the drain freezes over because the air temperature and the metal heat shield are still cold enough to freeze the drain. You can cut away a small portion of the metal pan liner and expose the drain to the heater coil while defrosting. I also wrapped a piece of copper 14 guage wire around the heating coil and routed it down the drain to heat it while in defrost. No problems after this fix.
May 31, 2014 | Whirlpool GB2FHDXWD Refrigerators
Evap coil freezes at top next to defrost thermostat
You will need to replace the defrost thermostat located on the coils. Here is the part to order.
Dec 03, 2012 | Amana DRS2663B Side by Side Refrigerator
Refridgerator side-by side dripping water drips to floor and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 06, 2011 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Freezer coils freeze up, refrigerator gets warm
You first need to check your defrost heater for continuity if none this is your problem if it has continuity it is good and you will need to replace your adaptive control board part # AP4010220 ? Enter your complete model # at www.appliancehelponline.com for illustrations and correct parts. The model # listed should have a few more digits thats why I ? the part # I listed. There is also a troubleshooting page that can help walk you thru testing these components.
Mar 28, 2010 | Amana ASD 2624 Side by Side Refrigerator
Refrigerator wont stay cold.Freezer works fine,no frost buildup
i replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 27, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Crosley Frost free Runs continuously
Try not to panic firstly, if you open the door and it starts to run then it was not running before hand right? or did I miss something?
Temp guage or thermostat I think this is one and the same leave it at a midway position for a while and lets see if it reaches temp in the fridge or not.
Jun 24, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Coils in freezer freezing up
The defrost heater is bad . remove the back cover - defrost annd fix it.
May 07, 2009 | GE Refrigerators
Crosley Servidor WCR17/E K3 Top Shelf and Drain Plug Freezes Over
first thing I would suggest is to flush the drain line. defrost any ice in the drain and then flush warm water thru the line until it flows freelyif  your having a hard time getting the line flushed out you may try using a large syringe or turrkey baster filled with warm water to forcfully flush water thru the line. this will most likely fix the problem.
you didnt mention if food was freezing in the refrig as well as the drain but there may be an off chance that the temperature control could be bad. since this is a manual defrost unit it depends on above freezing temps to help keep frost off of the cooling coil. if the temp control goes bad it will allow sub-freezing temps and possible drain freeze ups. so if the drain continues to freeze you will need to replace the temperature control.
if it comes to that, the control actually has a part number on it since maytag cant find your model number.
message me back if you have any further questions. thx peyton
Jan 30, 2009 | Crosley CRS40 Manual Defrost Compact...
Samsung RB2055Sl Top refrigerator couling coil freezing up every 2 or 3 weeks
The problem is freeze up. Bad door gasket or too much window shopping are the biggest issues. Could be low gas. Either take off the back freezer panel and defrost or unplug for 2 days to defrost fully. Oh, and clean the condenser coil. Then, let's see what the unit does.
Nov 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
73 people viewed this question
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
fta777
Colin Stickland
Colin Stickland
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
