Question about Haier CWH18A Commercial Cool 18,000 BTU RAC Electronic Control Window AC Air Conditioner w/ 16,000 BTU Heater - R-104A Refrigerant, 4-way Air Flow, 3 Cool Setting, 3 Fan Setting, 24-Hour on/off Timer, Auto Restart, 208230 Volt. Covers 700 - 1,000 sq ft
Haier cwh18a will not work in heat mode
Heat will not come on when the unit is in heat mode but seems to work fine in a/c mode
My haier hpp12xct-lw is accumulating water in air mode
So it's likely not fully evaporative. Must be high humidity and auto evaporate can not keep up. It just means your unit is working great. Drain it!
Aug 10, 2017 | Haier Heating & Cooling
I have a Haier air/heating unit. The heat has stopped working.
Keep heating mode and temp setting at minimum 3 to 4 degree C* between room and required temp.
If still not working, replace the heating sensor.
Tnx
Nov 13, 2013 | Honeywell ER150B Air Conditioner
Won't change from fan mode
you more than likely need a new control board or front display control board
Aug 09, 2013 | Haier Heating & Cooling
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
How does the heater part of the CPN12XH9-E work? Does the hoses need to be in window still?
Yes, hose needs to connect to outdoors, since it operates as a heat pump. You'll notice cold air blowing out the exhaust when in heating mode, and hot air blowing out the exhaust in cooling mode - unit exhausts opposite of temperature you want.
Jun 13, 2011 | Haier HEATER CPN12XH9 Air Conditioner
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is on...is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
Carrier heat pump: aux heat does not seem to work
The unit is probably to small for theare you are trying to heat.
When the Aux HT light came on that meant the heat pump could not keep up with the demand for heat. (Probably due to extreme cold, or undersized unit.)
If yu have heat, then at least one heat strip is operating. If you have multiple heatstrips, one or more could be malfuncioning.
Or it could simpy be to cold/to small fr your area and not able to keep up.
How many square foot are you trying to heat?
What is the outside temp?
What is the inside temp?
What size unit (BTU output) do you have?
Dec 22, 2008 | Haier Energy Star ESA3183 Air Conditioner
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Haier CWH18A Commercial Cool 18,000 BTU RAC Electronic Control Window AC Air Conditioner w/ 16,000 BTU Heater - R-104A Refrigerant, 4-way Air Flow, 3 Cool Setting, 3 Fan Setting, 24-Hour on/off Timer, Auto Restart, 208230 Volt. Covers 700 - 1,000 sq ft Logo
21 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
