Question about Maytag MDE4806 Electric Dryer
Maytag md-1 squealing
Dryer started squealing this afternoon
  • 311 Answers
SOURCE: Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Healeyman
  • 1198 Answers
SOURCE: Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Posted on Apr 28, 2009
localwonder
  • 6784 Answers
SOURCE: Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
Posted on May 21, 2009
  • 251 Answers
SOURCE: My Maytag Dryer MD-1 makes a screeching sound when
the dryer drum has a rear bearing but on the underside it rests on two idler rollers , these can be the cause , best to replace them
Posted on Oct 20, 2009
  • 14 Answers
SOURCE: Maytag electric dryer is making a high pitched noise
Maybe your problem is coming from the bushing shaft part. Mine was so used that it made a terrible and high pitched sound.
Try to look behind your machine, remove the part hidding the bushing shaft and check if everything is ok.
My bushing shaft was make of metal, and I replaced it with a teflon one. Everything is working fine right now.
Have a good day.
Posted on Sep 13, 2010
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
May 21, 2009 | Maytag Dryers
Feb 28, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE4806 Electric Dryer Logo
16 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
