Question about Prenco 1996 - 2001 Toyota Camry Direct Ignition Coil Boot W0133-16343
Ignition locked on a 1996 Toyota Camry - Prenco 1996 - 2001 Toyota Camry Direct Ignition Coil Boot W0133-16343
    Problem Solver:
  • 5 Answers
If the steering wheel won't move either, then just put the key in the ignition and wiggle the steering wheel or pull a little harder to the left while turning the key. Happens all the time when people push themselves out of the car by the steering wheel. They lock the steering wheel, which locks up the ignition.
Posted on Apr 26, 2014
How do i unlock child lock on 1996 camry
page 14 of your owners manual shows how to lock unlock the child proof setup on door -----open door and by latch will see the the lock move to unlock position ! CAUTION LOCKING WITH REAR DOOR CHILDPROTECTORS Turn the lock knob to the "LOCK" position as shown on the label. This feature allows you to lock a rear door so it can be opened from the outside only, not from inside. We recommend using this feature.... the link is a copy of your owners manual
1996 Toyota Camry Owners Manual
Aug 11, 2016 | 1996 Toyota Camry
HOW DO I FIX THE IGNITION SWITCH ON A 1996 tOYOTA CAMRY SEDAN
switch needs to be replace. the ignition key works starts failing just like the starter itself it starts ok at first and starts to go every time you try to start your car until it goes no more. replace as soon as possible or you will end up calling a locksmith.
Oct 06, 2014 | 1996 Toyota Camry
96 camry ignition key very hard to turn. have to violently jiggle, turn wheel, stomp brakes to get ignition to turn. is it ignition, steering lock, breaks?
Have you tried getting a new key cut? Worn keys can do that. Other than that I would say a worn out ignition lock cylinder. Mike
Jun 14, 2011 | 1996 Toyota Camry
What fuse controls the automatic locks on a 96 Camry V6 LE?
CHECK ALL THE FUSES WITH A GOOD FUSE TESTER, UNDER THE HOOD & INSIDE THE CAR. TURN ON THE IGNITION SWITCH DURING THE TEST.
Jan 23, 2011 | 1996 Toyota Camry
I unhooked the battery now i cant stop the horn and it wont start the remote key does not work it got washed in clothes help please.97 camry
Lock then unlock the doors with the power lock button, with all doors closed (key not in ignition). If this doesnt work, try again using the key to lock and unlock from the driver door, with all doors closed.
May 12, 2010 | 1996 Toyota Camry
96 Toyota Camry keys are not working to open locked door from outside. First the passenger side and now the driver's side door.
Try spraying some silicon lubricant into the keyhole and slide the key in and out a few times.
If this does not work you may have to remove the interior door panel and trouble shoot the lock mechanism.
It's also possible the lock cylinders are worn and need to be rebuilt. This can be done by a qualified locksmith (look for a AAA certified locksmith). Or you can order new lock cylinders and get them re-keyed to match your ignition key.
Dec 16, 2009 | 1996 Toyota Camry
Can't turn key all the way on 1996 Toyota Camry.
Is your steering wheel locked? Turn the key as much as you can, then turn the steering wheel and see if it releases the lock. You should be able to completely turn the key after this.
Jun 28, 2009 | 1996 Toyota Camry
IM HAVING PROBLEMS GETTING THE OLD IGNITION OUT. THE IGNITION IS COMING OUT OF A 1996 TOYOTA CAMRY. WHAT DO I NEED TO DO?
You may have to drill out the lock pin in the cylinder. This is the pin that you have to push in to remove the cylinder.
Mar 23, 2009 | 1994 Toyota Camry
Can not turn the key .on my 1996 toyota camry
Look for a certified diagnostic centre so your car can be properly checked. I suspect that it has a security code issue. It can only be corrected that way. Try it out and get back to me. +2348023080045
Mar 17, 2009 | 1996 Toyota Camry
Toyota Camry power windows not working from master switch
Their are two fuses that power this system. One is a 15 amp gauge fuse and the other one is a 30 amp main power fuse. You can also check the power main relay, your ignition switch, or i could possibly be a fault in the wiring
Mar 11, 2009 | 1996 Toyota Camry
Prenco 1996 - 2001 Toyota Camry Direct Ignition Coil Boot W0133-16343 Logo
76 people viewed this question
Top Prenco GPS Experts
Are you a Prenco GPS Expert? Answer questions, earn points and help others
