Question about Refrigerators
How do I remove the front control panel on the GE french door refrigerator model number PFSS6PKXCSS to replace the ice chute part number WR13X10737
  • Refrigerators Master
  • 4,655 Answers
I believe this manual HERE will instruct you beginning on page 53. Correct me if I am wrong, Thanks John Tripp Appliance 911
Posted on Feb 14, 2014
  • 4 Answers
SOURCE: Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Posted on Jul 06, 2007
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
peyton32034
  • 410 Answers
SOURCE: replacing door chute on kenmore refrigerator 57562792
first of all unplug the refrig.
look at the bottom of the disp cover and you will find 2 slots for you to slide in a flat tip screw driver. carefully pry the bottom of the cover loose 1 side at a time.once this is loose, either remove the 2 screws that hold the switch housing in place or release the clips ( depends exactly onwhich model you as to wether there are clips or screws) once this is free remove the plastic funnel, by this point you should see how the chute door removes.
a few notes the disp cover can be hard to remove but it will come loose also reinstalling just hit it firmly over each clip witht he palm of your hand.
good luck..
Posted on Dec 19, 2007
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
pilungu
  • 30 Answers
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
GE Model PSIC3RGXBV. Inside freezer at top of ice chute, frost builds up. Returns after wiping. Happens on Humid and non-humid days. Empty nesters so doors are closed quickly. All vents inside clear.
the model number didn't come up,but if you have an air leak most likely it's gonna be the ice chute door itself not fully closing,you can get paper towels,and stuff them into the chute hole for a couple of days to see if that's the problem,another thing is open the door and put a light in front of the chute door and look down the hole,if you see light then the door isn't sealing or check the door gasket for any tears
Nov 01, 2017 | GE Refrigerators
Panel keeps flashing and ice door keeps opening and closing
You have a maytag refrigerator and it has a bad main pcb (on the back of the unit). Put a rag in the ice chute to keep the door from making so much racket. If you post your model number I will get you a part number.
If you want to verify what I am saying you can unplug the unit and remove the cover panel from the main pcb on the back of the fridge and one or two of the capacitors will be rounded on the top, not flat like the others. If that is the case then that is the problem.
Mar 13, 2013 | Maytag Refrigerators
GE Profile PFSS6PKXCSS leaks under crisper
i have a ge thats doing the same thing ine has a live running on back dont know if i unhook on back or tahe off control box hey go 2 http://www.partselect.com/ they have diagras and a help solution page let e know when u find solution
Dec 29, 2012 | GE Refrigerators
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
Our frig ice cube door chute keeps slaming and the lights are going crazy on the push button board. model MFI2568AES SER 10967637JR
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Oct 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The temperature panel is blinking on our refrigerator, the ice chute door at the bottom of the chute keeps opening and closing on its own. I can't get it to stop. I unplug it, but when I plug it back in,...
The problem is the high voltage control board located behind a panel on the back of the unit & needs to be replaced. In the meantime, on the front left hand side hinge is a cover. Remove the cover, You will see a plug connector. Unplug & re-cap till you receive the replacement door. It'll stop the unit from flapping... Hope this helps... Bill
Jun 04, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Ice dispenser door flap does not stay shut
IS IT A GE? GE HAVE A PROBLEM WITH DOOR SOLENOID IN CUP CHUTE RUSTING,GET A FLASHLIGHT AND LOOK UP THERE,IF IT IS RUSTED YOU WILL HAVE TO REMOVE FRONT PANEL AND REPLACE IT,THANKS-MIKE
May 30, 2008 | Refrigerators
Ice chute door on maytag refrigerator
the door is opened by a solenoid. it is bad or it is not getting voltage due to bad control or wiring
Apr 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
229 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
