How to drain the water of washing machine Crystal
Crystal BR 689 washing machine.Finish washing but doesn`t drain the water. Filter checked-nothing there
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
  • 142 Answers
SOURCE: Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Posted on Jan 25, 2009
  • 35 Answers
SOURCE: washing machine not draining the water
the weater pump is bad replace....
Posted on Apr 13, 2010
SOURCE: servis 1200 rpm machine,water does
my washing machine does not spin all the water out
Posted on Apr 29, 2010
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Washer stoped and did not finish rinse cycle now it makes a humming sound and code nd
Washer Error Codes ND IS -No Drain There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is sliping or broken
  1. Unplug the washer from the electric outlet.
  2. 3Open the case, and disconnect the water hose from the outlet of the water pump.
  3. 4If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
  4. 5Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
  5. 6Reassemble hose from step 3.
  6. 7Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
  7. 8Reassemble washing machine case...you're done...
Oct 11, 2011 | Washing Machines
Nextra HNWF 3135 doesn't work hole cycle, after washing stops, doesn't rinse or spin, these steps I must set up manually, because it doesn't do. I've tried to do with different programs...
Ok hot water being still there and not draining is a clog in your drain line or pump issue. I have not yet brought up the schematic to your unit but on some units there is a clean out filter located down the bottom in which you would clean out the filter careful water does come out when you unscrew the filter on other models that do not have the filter door you would remove the lower panel on the front which would give you access to the pump and the drain lines as well even though if you do find items in the filter you still need to disconnect the drain lines going to and leaving from the pump to assure that nothing is blocking or clogging the flow of water. Im glad you replyed about the hot water still being on the inside definite clog in the drain line or pump or filter issue. If you have any further questions message me back. I await your reply Thanks
Rick
Sep 25, 2011 | Hoover Nextra HNWF 3135 Front Load...
Model LTF2140FS1 washer: last load did not finish, water still inside, try to turn on machine and it makes a loud buzzing noise and nothing else.
Hi rrudrow,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Washing Machines
Hi. I have a kenmore Washing Machine model 27062601 It doesn't finish the cycle. stops wen is washing, then I have to open it and start the cycle again. some times this works, some times don't. ...
Hi xochipiliti,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
Kind Regards
JEDEMEYER1
Sep 05, 2011 | Kenmore Washing Machines
Keeps saying F21 and will not finish washing
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not finish its rinse or spin cycle
Check that water can drain out of the machine
1/ Check that the filter is not blocked
2/ Check drain motor is working (ie. not blocked with coins or hairpins etc)
3/ Check that pipe from tub to filter is not blocked (I had a sock blocking mine)
4/ If there is water in the filter and the drain motor runs then check that waste water hose is not blocked.
Aug 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
NOT FINISH CYCLE
Check filter otherwise jammed or faulty pump
Jun 10, 2009 | Indesit W 123 Front Load Washer
Washing machine not draining water during washes
hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
Hoover optima AAA1600 hntf 6167 washing machine
Most washers have a drain hose that is mouted high to keep the water in. If you drop the hose to floor level it will drain with out help. Be sure you have a floor drain or bucket. Then check the belt on the motor if there is slack it will not engage the pump for drain to operate. Need to tighten the belt.
Mar 25, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
