Question about Generac Electrical Supplies
Generator wont run
Will start, but quits immediately
    Sergeant:
  • 415 Answers
Most likely a dirty fuel system. Rebuild the carbureator and put in fresh fuel, preferably non-ethanol fuel. That should work.
Posted on May 23, 2014
2 Suggested Answers
SOURCE: 6.5KW Onan generator. wont run when the start button is released
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Posted on Mar 23, 2009
My onan 4.0 generator will not idle and is back fireing while trying to run it will run fine for ten min then starts trying to die and starts back fireing when I try to keep it running
check for a faulty sump oil switch . check for faulty coil ( magneto on the flywheel) as the time it runs suggests that it is breaking down internally.
Feb 11, 2015 | Onan CUMMINS 4.0 KYFA/6747 - Cummins...
RUNS AND QUITS
You could try replacing the ignition coil. If it's failed, then it may run ok for a few seconds, but as it heats up it fails. Trying to start again immediately will be too soon for the coil to have cooled down. Leave it a few minutes to cool down and it will run again, but only for a few seconds again.
Hope that helps
Jan 03, 2014 | kawasaki 2011 Teryx 750 FI 4x4 Sport
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
Check rotor slip rings for cleanliness, brushes, stator resistance, rotor resistance. Then replace control board if they check out.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
Nov 17, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
How do i disconnect the low oil sensor
Some oil sensors will stop the generator from running if unplugged, IE they close the circuit on oil pressure, some close the circuit on oil pressure. I wouldn't recommend but with it running just take the single wire off the sensor, if it stops immediately then it requires the signal grounded to run. Some ground on low oil.
Oct 26, 2012 | Coleman Powermate Subaru 5000W Portable...
If I lose street power momentarily and my generator immediately starts than quits because the street power comes back on, the weekly 20 minute generator excercise does not work.I have to reset the transfer...
Although A bit inconvienent this does seem to be the norm for some Kohler units. Actually a small price to pay rather than having a technician come out to replace the ATS control board. There are time delays that could be set longer to keep the unit running longer and may prevent this from happenng
Jan 03, 2011 | Kohler 18RESL 18 kW Emergency Power...
Jan 08, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
53 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
