ScandAll Pro Barcode Recognition
I am using ScandAll Pro 1.8.1 (free with the purchase of an Fujitsu fi-series scanner), and I have spend about a month familiarizing myself with the interface and establishing profiles. My main profile uses barcode recognition to separate batch documents, and up until now the software has had no problems with recognizing the barcode and sorting/saving the PDF's by the barcode number. But I recently tried to scan a particular document package (by itself) and ScandAll cannot read the barcode (saves the file as "SEPARATOR0001_2-13-2014"). I tried to use the separator sheet of the document package as the barcode recognition page in the profile Document Separator setup, and when I try to "Recognize Barcode" it doesn't produce anything, for all four barcode types. Any suggestions on what might be causing this? Thanks in advance!
3 Suggested Answers
  • 43 Answers
SOURCE: HP7800 scanner scans multiple pages, only saves last page to PDF
Hi
i had the same problem- I unistalled all the software and then reinstalled and load this patch PDF patch from HP solutions centre and it fixed the problemhttp://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=1151021&prodNameId=1151022&swEnvOID=181&swLang=8&mode=2&taskId=135&swItem=cs-75419-1
Regards Liz
Posted on Feb 22, 2010
mohanchennai
  • 490 Answers
SOURCE: I'm scanning a multiple page document and each page is being saved as a separate file. I want the multiple page document to be saved as one file.
You have an option to create a multipage (PDF) file or single images. Please select appropriate option.
S. Mohan
Posted on Apr 04, 2012
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
Blank backsides not deleted
Hi Keegan,
Please check the blank page skip adjustment in the settings option. You may also refer to the TWAIN driver and ScandAll Pro application(if using) help guide for details.
Thanks,
ScanCare
Apr 04, 2012 | Fujitsu fi-5900C Pass-Through Scanner
Can you pls. suggest which PCI Xpres card support Fi-5530C2 Scanr
Hi Karthik,
Please click on the following link for recommended SCSI cards for your Fujitsu Fi-5530C2 scanner .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/scsi/
Please revert for further clarification.
Thanks & regards,
TechSatya
Jul 26, 2010 | Fujitsu Office Equipment & Supplies
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Nov 16, 2009 | Fujitsu fi-5530C Scanner
Scandall 21 Automatically Saves Scan As Temp Fil
go into the settings on your computer and change the setting to save all scans
Jul 20, 2009 | Fujitsu fi-5530C Scanner
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Keep scandall in background
Possibly you need a more professional program. Scanning utilities following scanners (free) aren't a "Production" tool. Using PixEdit you can scan with one single click and after the scan is finished you could scan the next stack of pages. While it is then scanning the previosus document is processed with blank page removal, deskew, OCR, barcode recognition and a lot of other stuff. The reason is PixEdit using the mulitple cores in modern PCs.
Sep 17, 2008 | Fujitsu fi-5120C
Can't setup ScandAll 21 on fi-5120C
why do you want to use the older version, the new version has much better driver support and actually works with the event buttons on the scanner.
May 23, 2008 | Fujitsu fi-5120C
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
94 people viewed this question
jasbo
jasbo
