Question about AquaSource Stainless Steel 1-Handle Pull-Down Kitchen Faucet 0478000A
Soap dispenser bottle for an Aquasource faucet broke. Need to replace
I would like to replace my shower handle and skirt. Are Delta parts compatible with Aquasource?
go to your local plumbing supply they will give you handles and trim parts that will fit in different stiles for your brand faucet
Apr 13, 2016 | AquaSource Stainless Steel Replacement...
I have a waterridge faucet and need a soap dispenser bottle. Where can I find one?
Just found out a customer service number for them to order parts: 888-648-6466
Jun 07, 2012 | Plumbing
The threaded shank for the soap dispenser broke on our Price Phister model KSD-M1YY soap dispenser. Can't find a replacement. The model # of the faucet isT26-4DYY. Can you help?
Most parts can be ordered though Price Pfister Directly 1-800-PFaucet. Here is a link to the parts diagram for your faucet. http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/treviso/tret26-4d/ex-026-02.pdf  If by threaded shank you are talking about the bottle, then you can order just a new bottle (Part # 950-004) if not you may need to order a whole new soap dispenser (Part # 920-054.) If you order a whole new soap dispenser than make sure you order the correct finish to match your faucet.
Oct 09, 2010 | Price Pfister Marielle Kitchen Faucet with...
I bought a tuscany faucet from Menards and the soap dispensers plastic hose that screws into the bottle that you fill with soap cracked. Can I just buy a dispenser?
You can buy replacement soap dispensers at Lowe's, Home Depot and most home centers and hardware stores starting at around $22.
Aug 09, 2010 | Plumbing
We have the single handle Pegasus 190 571 Brushed Nickel bathroom faucet. The soap dispenser got knocked and broke off and I cannot find a replacement for it.
The booklet that comes with that unit has the following part numbers: nut set (A66D111); soap dispenser sleeve (A665597); soap pump (A605230); soap dispenser nozzle (A66596). Those are all the parts (less plastic tube and soap reservoir bottle) for the dispenser- you probably only need one (the broken one!).
Jun 17, 2010 | Home
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
The bottle that contains the soap for my sink broke off, leaving the top of the bottle in the base of the squirter under the sink. How can I take the top of that plastic bottle out so I can skrew in a new...
Hello. You will find that the bottle will come out once you remove the nut under the surface of the sink.
You have to get into the cabinet to do this. And, a faucet wrench, available at any hardware store will assist you greatly. Regards, joe
Oct 18, 2009 | American Standard Contemporary Kitchen...
Re: soap dispenser of my K-R10430 Kohler 4-hole faucet. The small spout has started coming out of the body of the dispenser when dispensing detergent. Installation and homeowners guide don't show whether...
I'm not sure if it can be repaired or not, but lowes carries the same dispenser that came with faucet. To replace unscrew bottle from under counter now you remove plastic nut that holds the body to counter and install new one.
Sep 28, 2009 | Plumbing
It seems that the plastic pump mechanism is not
Unfortunately it is a very common problem with soap dispensers. First before you replace the dispenser, dillute a small amount of water mix with the soap in the bottle of the dispenser to see in fact if the pump is deffective. It could simply be that the soap is too thick for the pump to work properly. As to replace it, call the manufacture of the faucet which I presume came with the dispenser and very often they will stand by their products and send you one free of charge.
Feb 20, 2009 | Price Pfister Marielle Kitchen Faucet with...
How do I replace soap dispenser pump mechanism?
Our brand new Avalon model had this problem. It sure appears to be a design defect or defective part. After contacting customer support, they sent a replacement pump (the internal part, not the whole unit).
After removing the unit from your sink, holding the top pull firmly with constant pressure on the pump assembly. It will pop off, but you have to pull pretty hard.
I suggest running water through the top of your unit before putting the new pump assembly on it. Ours had black 'junk' inside even though it was brand new. The new unit just slides on in the reverse process of removing the old one.
Oct 30, 2008 | Price Pfister Marielle Kitchen Faucet with...
AquaSource Stainless Steel 1-Handle Pull-Down Kitchen Faucet 0478000A Logo
235 people viewed this question
Top AquaSource Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you an AquaSource Plumbing Expert? Answer questions, earn points and help others
