Question about Xerox Color 550 560 Colour Drum Cartridge 013R00664
Xerox 550/560 fuser problem - Xerox Color 550 560 Colour Drum Cartridge 013R00664
Error 010327 in xerox work centre 5222
That error signifies a defective fuser unit. Replace fuser, part number 126K24980.
http://www.iteminconline.com/126k24980_126k24980-126k24981-126k24982-126k24983-126k24984-xerox-workcentre-5225-5230-fuser-110v-new.htm
Feb 22, 2016 | Xerox Office Equipment & Supplies
How to fix fuse failure code 0500 phaser 6121 Xerox
0500 is a fuser failure error. Need to replace fuser.
http://www.iteminconline.com/126e02770_126e02770-xerox-6121mfp-fuser-110v-new.htm
Nov 15, 2015 | Xerox Office Equipment & Supplies
How to clear error 10-333 on xerox 7132 all in one
That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
http://www.iteminconline.com/008r13022_008r13022-xerox-workcentre-7132-fuser-110-volt.htm?source=froogle&gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzZg4C5Qd7jYhL14rJSJWIPdkZdVrtP4kPg2RlOQFweIaAnzV8P8HAQ
Apr 26, 2015 | Xerox Office Equipment & Supplies
How to fix xerox docucentre 2056 error 010-327
That error signifies a defective fuser, not coming to temperature. Replace fuser, part number 126K24980. See link below:
Jun 10, 2014 | Xerox WorkCentre 52255230 Copier
Xerox 3050 fuser replacement
Assuming you are talking about the Xerox 3030/3050 wide format printer, you don't replace the fuser, only the individual components eg. fuser roll
May 11, 2012 | Xerox Office Equipment & Supplies
Error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Apr 12, 2011 | Xerox CopyCentre C118 Copier
Sir 010-398 in my colour xerox machine model no 1632 plese give me solusation whats problem give me answer
010-398 Fuser Lock Failure RAP
Description
The Fuser Fan failed.
Power OFF/ON
Procedure
Turn on the power.
Visually check the rotation of the Fuser Fan
Feb 26, 2011 | Xerox DocuColor 1632 Laser Printer
Xerox 6250 will not warm up. it says
Yes it can be the used fuser. Kind of odd for it to be anything else but the fuser.
Jan 25, 2010 | Xerox Phaser 6250 Laser Printer
How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Ibm info print 40 fuser 90h3567 same as xerox n40 fuser 109r486
Xerox put identity chips into their consumables and I presume IBM do the same which means even if the fuser is exactly the same your printer is going to reject it as a incompitable part
Sep 08, 2009 | IBM Infoprint 40 Laser Printer
Xerox Color 550 560 Colour Drum Cartridge 013R00664 Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
