Question about Braun 360° Complete 8985 Electric Shaver
Cleaning base my cleaning base for my braun 360 complete 8985 razor will recognize when i put a new cartridge of cleaning solution into the base but when i put my razor in the base it will not auto select it for cleaning. when you press down on the lock to start cleaning nothing happens. i have tried to clean everything as best that i can. really appriciate the help.thank you ryan
  • 5 more comments
  • SpeedBug Nov 11, 2007
    I have a similar problem, only mine started when I replaced the Shaver cutter/head. I replaced it with the Braun part specified for the 8000 series I picked up at WalMart. Now the base will not run any cleaning cycle, reservoir level light comes on(full), but the cleaning cycle light does not come on at all.
  • Beamen Jan 24, 2008
    I have the same problem, i replaced the cutting block and foil with the correct braun parts, now it wont ever select a cleaning method. It does charge while in the cleaning dock, so i know the contacts are ok.
  • popozozo51 Feb 16, 2008
    My cleaning base tell level of solution but no longer indicates cleaning level or starts cleaning process when lock bar ispressed. My unit is only about 2 months old.
  • Anonymous Apr 20, 2008
    The cleaning base of my husband's Braun shaver does (or doesn't do) the same thing-- it recognizes the level of cleaning solution, but doesn't appear to detect the shaver (although the shaver appears to be charging, suggesting that the contacts are still intact). The shaver cradle is flooded with cleaning solution, but the cleaning cycle will not start. I did notice that just prior to this problem occurring the shaver seemed to have self-initiated a cleaning cycle (no one had touched the shaver-base unit for at least a few days), but was 'stuck' in the cleaning cycle. The base sounded like it was 'trying' to clean the shaver, but just didn't have the strength (didn't sound like normal). The noise stopped when I touched the unit, and then I discovered that the base no longer detected the cleaning level needed. Anyone have any solutions?
  • praise Him Apr 20, 2008
  • Anonymous Jun 17, 2008
    My base does not charge or clean, though it does detect the level of cleaning fluid. The contact points are clean, springy, etc and I can visibily see are contacted with the shavers when it is inserted?!
  • Anonymous Aug 16, 2008
    The base recognizes a new cleaning cartridge but will not indicate a cleaning level or reset to clean. The charging operation is ok. Everything has been cleaned thoroughly, but still no cleaning cycle.
I have been shaving with electric razors for 48 years, and the Braun 8595 is by far the best one yet.
I have had the problem of the refusal of the cleaning station to recognize the level of fluid in the cartridge, three times over the last couple of years. It seems to relate to a build up of shavings in the unit. To get it working again I inverted the unit, and carefully flushed water via a small tube, back through the 1cm diameter hole in the underside of the open base. Of course, the unit must then be thoroughly dried before use, or the sparks may fly. Does anyone know how to dismantle the unit for a safer and more thorough clean?
Posted on Aug 09, 2008
  • Gene Pitts Feb 10, 2014
    #1-Remove cartridge,unplug unit from charger & from base. #2-Hold base upside down. With a SMALL straight blade screw driver carefully pry the two 1/4in spring wedges away from outer case. Some resistance will argue with you in separating the outside shell. Proceed with caution in cleaning pump & ckt bd. When reassembling confirm 1/4in lock pads are ALL the way. Good Luck.
Does the charge light on the razor come on when the shaver is in the base?
The base communicates with the shaver through the charger contacts, so if you
don't have good contact the shaver won't charge and the base won't know that a
shaver is present.
Check that the metal contacts on the base are clean and "springy", and not loose or displaced.
If the shaver charges fine in the base but you can't start a cleaning cycle, I'd
suspect the electronics in either the base or the shaver. Even if the mechanical
switch in the base were faulty, the cleaning-status LED's in the base should come on when it connects with a shaver.
Posted on Nov 05, 2007
Do this at your own risk. If you're too stupid to follow directions, then don't do it.
Ok, real simple: the surface of the metal contacts on the base that touch the contacts on the shaver have oxidized partially. A quick fix, if you find that Braun's technical support is as worthless as the pathetic alloy used to make these oxidized contacts, take a small piece of aluminum foil and cover each of the contacts on the base, separately. Tape it down, or something, but make sure the foil touches the metal contact surface. Make sure that the aluminum can touch the contacts on your shaver. AND make sure that these aluminum pieces are not large enough to touch one another, because then you REALLY risk ruining the base and the shaver, and you are the only one to blame. All you really did was give the shaver "new" contact points on the base to connect to. Works for me, and I don't see these foil pieces when the shaver's plugged into the base, so I don't care. A (nearly) free, quick fix.
Posted on Dec 14, 2008
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
Jun 12, 2010 | Braun 360° Complete 8985 Electric Shaver
8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
Just don't beat it against anything hard.
Oct 29, 2009 | Braun 360° Complete 8985 Electric Shaver
Cleaning base thinks it's empty
I had the same problem. Try taking out the cartridge and in the compartment where the razor sits in to get clean, there is a drain hole on the left side. Try cleaning the hole out with a toothpick or something similar. It seems that the drain hole clogs and causes this problem. I just did it and all seems to be working fine.
Cheers
Feb 10, 2009 | Braun 360° Complete 8985 Electric Shaver
EMPTY!?!?
The "empty" light is for the cleaning solution. It needs to be replaced with a new clean cartridge. There should be a big button on the back of the cleaning unit which opens it up and allows you to replace the cartridge.
Jul 02, 2008 | Braun 360° Complete 8985 Electric Shaver
Shaver locked into base
Push down on the blue switch that activates the cleaning system. The switch should be flush with the rim of the cleaning well in order to release the razor.
Jan 12, 2008 | Braun 360° Complete 8985 Electric Shaver
360 is saying empty
I just fixed it now .. when the cartridge is inside and full turn the whole bas upside-down for less than a sec .. ( while the power plug is disconnected ).. then try plugging and cleaning again
Dec 24, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 360 Cleaning base
When you are looking top down into the cleaning base you want to look to the left side of the hole where you put your razor. That is were the solution drains out after your razor is cleaned and there is probably a blockage there. I used a toothpick to clean mine out every once in awhile when gunk would build up there.
Sep 12, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
1,062 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
