Question about RCA P52926 52" Rear Projection Television
*** ok com - RCA P52926 52" Rear Projection Television
I need the code to unlock Motorola E
The secret code for your Moto mobile phone
MOTOROLA
19980722 OK Master unlock code for phone and simlock
*#06# Display imei
*#300# OK List the software and hardware version
*#301# OK Full keypads functional test
*#303# OK Set default language to english
*#304# OK Set OFF engineering mode
*#304*19980722# Set ON engineering mode
*#307# OK Engineering test mode
*#311# OK Phone code changed to default code
*#402# OK Adjust display intensity/ contrast
*#403# OK List the manufacturing informations
*#302# OK Accoustict test
*#3370# Enhanced full rate
*#0000# OK Settings saved, restore set phone to default language
If it doesn't work, try to purchase the unlock codes from: http://www.ebay.co.uk/itm/Unlock-Code-Motorola-Moto-E-Moto-XT1022-XT1021-XT1541-XT1540-XT1524-/221439546897 or
https://theunlockr.com/2014/10/10/how-to-unlock-the-motorola-moto-e/
Apr 13, 2017 | Motorola Cell Phones
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
Tuner OK.SDL OK .scl OK .5v OK.33v OK.tunning OK .ic 9370/1717 OK .cabil OK but no ref signal
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 20, 2015 | Televison & Video
How to change language on panasonic phone kxtg4011n
Display language english --> Espanol
1 MENU
2 Initial setting" --> OK
3 Display settings" --> OK
4 Change language" --> OK
5 Select the desired setting.
6 OK-->OFF
Espanol-->English
  1. Menu
  2. Ajuste inicial-->OK
  3. Ajuste pantalla-->OK
  4. Cambiar idioma-->OK
  5. English--OK
Refrence the manaul: http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF
Oct 21, 2013 | Panasonic KXTG4011 Cordless Phone
Hi, I have a big problem with my lg L194WT,when I press power on button nothing happens. I open'd up the display case nothing looks wrong except a bad cap 1000 micro F/16V I replaced that. DC...
For 19" monitor, I would expect more tahn 12vdc for the inverter circuits, some runs as high as 19vdc, but since you are getting 5vdc OK, more likely may be OK but should be check out, that 1000uf 16vdc may be used for the 5vdc power supply section, the inverter power supply section will usually uses 25vdc caps.
Do you see the backlight lamps flash on for second at all? You may need test lamp to verify if the inverter circuits are OK or not, since bad lamp can cause the inverter to go into shutdown also.
There are also BL_ON (about 3.3vdc = ON) signal and PWM_DIM signal feeding the the inverter circuits.
I would attach a12v car lamp such as 1157 to the inverter 12vdc power supply section to see if it can maintain 12vdc with load (do not turn on the power switch during this test since the power supply is always on even the power switch is not activated).
Service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jul 06, 2011 | LG L194WT 19" LCD Monitor
How do I know this is the real/original ebayand not a fake
the url MUST be always ebay.com (or ebay.XX depending on the country from you're getting access i.e. ebay.it or ebay.fr)
it may occour that depending on your ebay navigation you can see other words before EBAY.COM for example fashion.ebay.com or motors.ebay.com this is normal and those pages are always part of ebay network. just keep in mind that the last two words must be always ebay.com
then: XXXXXX.EBAY.XX = OK YYYYYYEBAY.YY = NOT OK EBAYZZZZZZ.ZZ = NOT OK
hope it was clear
Jul 09, 2010 | eBay Auctions
Java runtime environment cannot be loaded
yes u need to download new veirosn of java ok www.java.com then update adobe flash player and shockwave player ok at www.adobe.com ok have fun thx nick
Oct 11, 2008 | Dell Microsoft Windows XP Home Edition
RCA P52926 52" Rear Projection Television Logo
12 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
