Question about AquaSource Plumbing
Trying to find a soap dispenser bottle for kitchen sink for aquasource faucet
  • 19 Answers
SOURCE: kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Posted on Jul 07, 2009
SOURCE: The soap dispenser on my price pfister kitchen
Two things spell trouble for these poorly engineered units:water and thick soap...
Inside these pumps is a metal ball for
the check valve. any water in your soap
will corrode this ball, causing the pump
to lose it's prime...
Using soap thats too thick (like Dawn)
will cause the soap to harden around the moving parts and impede the pumping
action. Try a thinner soap, such as inexpensive pink hand soap.DO NOT
ADD WATER! (See above)
Hope this helps.
Posted on Jan 21, 2010
jyackle5
  • 8197 Answers
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Mar 19, 2010
  • 299 Answers
SOURCE: I bought a tuscany faucet
You can buy replacement soap dispensers at Lowe's, Home Depot and most home centers and hardware stores starting at around $22.
Posted on Aug 10, 2010
SOURCE: i have Geyser Kitchen Bar Sink/ Spray Faucet and i...
I have a Geyser GF8 that also leaks at the turning joint. Anyone know how to dissamble one of these faucets?
Posted on Oct 30, 2010
The threaded shank for the soap dispenser broke on our Price Phister model KSD-M1YY soap dispenser. Can't find a replacement. The model # of the faucet isT26-4DYY. Can you help?
Most parts can be ordered though Price Pfister Directly 1-800-PFaucet. Here is a link to the parts diagram for your faucet. http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/treviso/tret26-4d/ex-026-02.pdf  If by threaded shank you are talking about the bottle, then you can order just a new bottle (Part # 950-004) if not you may need to order a whole new soap dispenser (Part # 920-054.) If you order a whole new soap dispenser than make sure you order the correct finish to match your faucet.
Oct 09, 2010 | Price Pfister Marielle Kitchen Faucet with...
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
The bottle that contains the soap for my sink broke off, leaving the top of the bottle in the base of the squirter under the sink. How can I take the top of that plastic bottle out so I can skrew in a new...
Hello. You will find that the bottle will come out once you remove the nut under the surface of the sink.
You have to get into the cabinet to do this. And, a faucet wrench, available at any hardware store will assist you greatly. Regards, joe
Oct 18, 2009 | American Standard Contemporary Kitchen...
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
Kitchen sink soap dispenser won't pump
Mar 08, 2009 | Plumbing
KOLHER Soap dispenser won't dispence soap.
Pull the dispenser out. Put it in semi hot water foe a few minutes to clean it. Then put the pickup tube in a glass of water and pump it untill water comes out. They get clogged with soap after so long.
Good Luck
Kurt
Mar 01, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
It seems that the plastic pump mechanism is not
Unfortunately it is a very common problem with soap dispensers. First before you replace the dispenser, dillute a small amount of water mix with the soap in the bottle of the dispenser to see in fact if the pump is deffective. It could simply be that the soap is too thick for the pump to work properly. As to replace it, call the manufacture of the faucet which I presume came with the dispenser and very often they will stand by their products and send you one free of charge.
Feb 20, 2009 | Price Pfister Marielle Kitchen Faucet with...
How do I replace soap dispenser pump mechanism?
Our brand new Avalon model had this problem. It sure appears to be a design defect or defective part. After contacting customer support, they sent a replacement pump (the internal part, not the whole unit).
After removing the unit from your sink, holding the top pull firmly with constant pressure on the pump assembly. It will pop off, but you have to pull pretty hard.
I suggest running water through the top of your unit before putting the new pump assembly on it. Ours had black 'junk' inside even though it was brand new. The new unit just slides on in the reverse process of removing the old one.
Oct 30, 2008 | Price Pfister Marielle Kitchen Faucet with...
Delta 989-SSSD soap dispenser loose.
Hi tsquared_030,
I'm Harvey the Master Plumber.
Your problem is: How do you tighten your soap dispenser to your granite countertop?
You can reach up behind the sink and turn the soap reservoir, and feel a ring with nubs extending from the ring. you can't seem to find the two parts that need to be screwed tight.
You will need a little help. First remove the top dispencer, it just pulls out. Time to go below. Carefully unscrew the soap bottle to get it out of the way. Have your helper hold the escuchen (the part on top) while you tighten that nubby ring underneath. I find it easy to do this with a basin wrench. If you can't lay your hands on one you'll have to make do with your hand but you won't be able to fully tighten and you may have to repeat in future. Have fun.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Delta 989-SSSD Allora Kitchen Pull Down...
Plumbing Logo
32 people viewed this question
Top AquaSource Plumbing Experts
Donni Steen
Tom Chichester
Are you an AquaSource Plumbing Expert? Answer questions, earn points and help others
