Question about Bosch WFMC2100UC Nexxt Essence Washer
Bosch won't wash and won't spin
Was working just fine until late yesterday afternoon. Is barely 2 years old. Most of the posts say that it's the brushes. Would brushes go bad in just 2 years? This machine is used one a week - not commercially. So we turn it on, water runs in, then it just sits there until the rinse water comes in and then sits again. Clothes are sopping wet. help?
4 Suggested Answers
  • 351 Answers
SOURCE: Machine is not spinning
check the carbon brushes in the motor or the belt.if its not these then it may be a timer fault see if you have power to the motor
Posted on Jun 02, 2010
  • 6277 Answers
SOURCE: I have a Bosch maxx
I suspect that there is water still left inside as the drain pump has been unable to complete its task so they are being spun in water!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 19, 2011
kevstu28
  • 17 Answers
SOURCE: bosch washer won't spin with wet clothes
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
Posted on Aug 03, 2012
Is it worth fixing a six yr old bosch front loader washing machine with E6 problem. Not going from rinse to spin
way late reply!!! sorry but go here and see what you come up with.
great site
https://www.repairclinic.com/RepairHelp/FaultCodeLinks
Jan 02, 2018 | Bosch Washing Machines
Machine won't start the wash cycle
All bosch appliances are sold with a two year manufacturers guarantee. Call 0844 872 8999 to arrange an engineer. Sounds like it could be any of the following Heater, PCB, Pressure switch or Motor fault
Mar 24, 2013 | Bosch Washing Machines
Bosch washer won't spin with wet clothes
Aug 03, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
Spin cycle not completing
have you lost any garments in the wash lately? there may be one in your pump causing loss of power on the suction. When the machine spins out, have you noticed a marked decrease in time or just the dampness of the clothes? This is what leads me to believe this is a clog in the pump or the hoses to drains
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
My Bosch Exxcel 1400S Express (WFX148SGB) just doesn't spin anymore. Everything else seems to work fine?
Bummers. Sounds like the clutch is out. (If you can hear the motor spinning but not the drum, I'd say that's it. Especially if the machine has a number of years on it.)
I once looked into having a service man come fix a clutch. He said it would be cheaper to buy and new washing machine and have the old one hauled away.
Good luck.
Nov 12, 2008 | Bosch Washing Machines
Bosch w ashing machine. will wash but not spin
i REMOVED AN ITEM FROM THE FILTER THAST WAS BLOCKING THE FLOW OF WATER. i THEN TRIED MY MACHINE, AND WOW!!!! IT WORKS.
Aug 31, 2008 | Washing Machines
Washer not turning on
Check the lid switch...sometimes the get loose on break and will could cause this type of problem
Mar 11, 2007 | Whirlpool LSB6300PW Top Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
