Question about LG DLE2050W 7.1 cu. ft. Front Load Electric Dryer
The dryer runs and after awhile the illuminated digital board goes out..like it has shutoff, but the dryer continues to run. I have to unplug it to get it to stop. But when I plug it back in it is still running..have to leave it unplugged for hours before it returns to normal.. but after it gets turned back on it does it all over again. Any ideas as to what is wrong??
    New Friend:
  • 66 Answers
The problem with display pcb...becouse of the humidity its some short sercuits,,,
Posted on Feb 17, 2014
4 Suggested Answers
SOURCE: Another LE error question
Had same problem last yr. about 2 yrs. old. Just happened again today. When i called LG last yr. they said unplug unit for 1/2 hr plug back in. I did this and has run fine until today I'm trying this process again and it worked.
Posted on Apr 10, 2008
SOURCE: My LG washer powers off completely after running
I had the same problem with my LG washer today. I found another post that said to hold down the start pause button 5 seconds, plug back in so you have power, run on drain/spin at highest spin speed. I did it and so far after each load it has not shut down.
Posted on Jan 29, 2011
Dryer runs, but why no heat?
Could be the thermostat has gone bad,or timer or heat control board
Dec 28, 2015 | Dryers
Dryer will not turn on. Lights blink and the Code "F-01" shows in the display
depending on your model The F-01 error code indicates a primary control board failure . If the error cleared after unplugging it for a while, then the control board could have received a power surge or glitch through the electrical lines. Completely disconnecting the electrical power and then reconnecting it will sometimes reset the board and it will operate properly. If your dryer continues to operate properly, then resetting the control board may have fixed your problem.
If the dryer motor continues to stop, then you may have a bad control board. A wiring problem or drive motor failure could also prevent the dryer from continuing to run properly. A technician is normally needed to diagnose and repair this type of problem.
If the F-01 returns and will not clear, then you will need to replace the control board in the dryer
Nov 25, 2015 | Dryers
We have an LG electric dryer Model number DLE2050W and when I turn it on it starts and runs but after awhile the illuminated board goes black,but the dryer continues to run. But it will not shut off.
I have an educated guess for you. A part of each control of a washer and a dryer is a little electric "clock". Those things can fail. I sounds like you may have a timer clock that is sticking and not advancing.
These " clocks" are a part of the times, and are not sold separately.
One way to possible tell would be to put your ear to the area of the control panel where the timer is and listen. Most of those "clocks" tick, and you can often hear them, or you can watch the dial, and it should advance with a click every so often.
Be blessed.
Feb 13, 2014 | LG Dryers
The dryer does not pass a 6minute mark. It continues to run and doesn't shutoff.
There are more parts to check and figure out this issue. Check door switch, then temp thermostat.
Aug 31, 2013 | LG DLE2514 Electric Dryer
Can I test the limit switch on my LG TROMM DLE3777w Dryer I think it is bad but am wondering if it was if it would cause my entire panel to power down/off. Also, would a faulty limit switch having...
if it has continuity it's good and isn't the problem,if the dryer starts and stops running after a minute you could have a bad computer board,when it stalls try tapping on the board and see if it starts,also unplug it and look at the board you might see something cooked on it or a soldier joint melted.
Dec 04, 2017 | LG DLE3777 Electric Dryer
Aeq6000 won't turn off
This has to do with the control board failure. The control board runs every aspect of the dryer and will need to be replaced. Here is the new control board.
Oct 20, 2012 | Frigidaire AEQ6000ES Electric Dryer
"Controls Locked" light lit, unlock button has no effect
Have you tried unplugging the machine for awhile to let the board reset?
Nov 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
DRYER WILL NOT SHUT OFF. CONTINUOUSY RUNS AND IS OVERHEATING.
The control board regulates the timer functions, yours may have failed
Nov 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
LG DLE2050W 7.1 cu. ft. Front Load Electric Dryer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
