Question about Toshiba E-Studio 3511 Color Copier
Toshiba e studio 451c error c360 - Toshiba E-Studio 3511 Color Copier
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Replace your toner sensor or tdk sensor
Posted on Feb 17, 2014
4 Suggested Answers
  • 643 Answers
SOURCE: Toshiba E-Studio 3511 error c360
C360 indicates Charger cleaner motor abnormality. Make sure the charger unit is installed & engaged to the drive gear. It is a common problem on e3511 model, where the main charger unit will loose.
Posted on Feb 08, 2010
  • 30 Answers
SOURCE: Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Thanks
Best Regards,
Posted on Aug 14, 2010
  • 10 Answers
SOURCE: MY TOSHIBA E STUDIO 451c HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Posted on Sep 05, 2012
Aug 11, 2012 | Toshiba E-Studio 3511 Color Copier
HI! I have one machine Toshiba C350 this is Color
Hello
The error code that is displaying, is the charger cleaner motor abnormality: Charger cleaner motor is not rotating or the wire cleaner is not moving normally.
Please try the following.
(1) Check if the main charger is installed normally.
(2) Check if the charger wire is broken.
(3)Check if any of the connector pins of the charger cleaner front/rear position detection switch is disconnected.
(4) Check if the cleaning pads are damaged or removed.
(5) Check if any of the connector pins of the charger cleaner motor is disconnected.
(6) Replace the charger cleaner motor.
(7) Replace the Logic board.
I hope this helps a bit
Regards
May 23, 2011 | Toshiba e-Studio 350 Copier
Other service call
Thanks
Best Regards,
Jun 30, 2010 | Toshiba Office Equipment & Supplies
Toshiba estudio 3511 keeps giving error c360. I've checked the charger and the gears are messed with drive motor. Motor turns initially but gets to stopping point and gives error. Is there a charger...
At our repair shop we have begun to put a small (1/8" or so) washer in between the frame and the bracket the worm gear is attached to when we get this error intermittently. It seems to pull that worm gear closer to the main charge cleaner gear to give it better meshing. Hopefully this helps you!
May 27, 2010 | Toshiba E-Studio 3511 Color Copier
Feb 05, 2010 | Toshiba E-Studio 3511 Color Copier
I need to set up toshiba 451C copier on network
Hi there
Foolow the link bellow for your manuals and a good online demo / tutorial
http://www.gioffice.com/Op_manuals.htm
Regards Alan "alstech"
Jun 29, 2009 | Office Equipment & Supplies
Printer not working
Try this link below to get the drivers you need:
http://copiers.toshiba.com/support/controllers/ebridge3511-4511.shtml
Sep 17, 2008 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Color Copier Logo
182 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
