Canon ir c5185 how to clear this error code e000751-0212
Canon ir c5185i
4 Suggested Answers
  • 1126 Answers
SOURCE: I have Canon IR-C5185i. Just assembled out of the
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable).
2. Turn ON the main power switch.
3. Change the setting values of the following service mode items.
- Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'.
- Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'.
Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1.
- Color Image Reader-E1: Platen cover model
- Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1)
- Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180)
4. Turn OFF the main power switch, and connect the DDI cable.
5. Turn the main power switch ON.
Note: How to turn OFF the main power switch.
When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine.
1. Hold down the control panel switch for 3 sec or more.
2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.)
3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
Posted on Nov 17, 2009
Testimonial: "Good suggestion. Problem isolated, but not fixed yet. Could you please help with question I added in the comments? (how to enter service mode?)"
spinal
  • 287 Answers
SOURCE: When checking the meter reading on my canon ir
Hello joe,hope you are well.Canon copiers have literally hundreds of "meters " that the device is constantly monitoring.Things like the number of 11x17 scans,reports printed,incoming faxes,outgoing faxes,prints at 600 dpi....etc.Its wild.The device is capable of displaying to the customer a total of six meters.The displayed meters may be customized for the customer by a technician as per the customers request or needs.Each meter is named by a number,for example "101".That particular meter indicates the total of how many sheets of paper(regardless of size) that have successfully exited the machine.102 meter indicates the total number of sheets that have been output using 8.5 X 11' as the basis.So a sheet of 11x17 paper would increment the 101 meter once,but the 102 meter would "click" twice.For billing purposes my company keeps an eye on the 102 meter to maximize profit,as it should be.Now how Canon determined the display of the other meters you see is a mystery.Again there is a meter named 958,which is the number of documents scanned to the MAILBOX. So, to completely answer your question: 108 is the total black and white copies made regardless of size.230 is just color and monocolor regardless of size.321 is{your gonna love this one}color prints on 11x17.322 is color prints on 8.5x11.So there ya' go! TMI city!!! Hope this helps.
Posted on Jan 07, 2011
Testimonial: "Spinal, This is great and will be a big help! Thanks so much for taking the time for such a thorough explanation. It's really appreciated. ...Joe"
spinal
  • 287 Answers
SOURCE: I cann't remember the password
Hello ttyree,
Wow. Ok, but you better give an atta boy with "FIXYA", cause you aint suppose to know this. We will have to go into "service mode" and this is not common knowledge as a customer can really hurt their device, and 3rd party service providers just love these tips.Awww hell, let's have some fun. ust stay with me. Dry run. Locate the "additional functions" located to the right of the didplay. Ok, you have located it, and in a moment we will press it and then release it and then press the numbers 2 and 8 at the same time and release and then we'll press the additional functions button again. This needs to be in a rather fluid motion like you do it all the time. * 2&8*. Don't give up keep trying if it dose work the first few times. Just press the "reset" button vigoriously after each attempt. At some point (perhaps your first shot [OOPS] } you will see the service mode screen, Please select the copier icon. Now the fun begins. Look across the top tabs and you will see "FUNCTION". Please press it. Now you see a new "menu" in the display. Look at the menu and highlight "CLEAR" and press "ok" at the lower right corner. New menu. use the arrows at the bottom of the screen (it may be already displayed) and find PWD-CLR. Select it and then hit the ok buton again. Press reset and exit and done and wahoo till you get to a screen that wallows the proper shutdown sequence. Or, if you have to, pull the plug as the changes we just made wont take affect till the true power cycles. You should be in good shape now. PASSWORW CLEARED. Live well.! :-)
Posted on Feb 04, 2011
Canon ir c3220 error code e000110 0110 how to clear this code
Here is a link to the error in the online service manual. This error may require replacement of parts prior to clearing
Canon iR C3200 Series Service Manual E110 0x10 Error Code
Aug 27, 2016 | Canon Office Equipment & Supplies
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
How to clear e000067 for canon irc2880i copier
What is the meanin of error e000067 for canon irc2880i - Fixya
www.fixya.com/.../t26059344-meanin_error_e000067_canon_irc2880i
Jun 6, 2010 - Question about Canon Printers & Copiers .... How to clear e000067 for canon irc2880i copier ... How to clear error 000062 canon ir 2880i.
How to clear error 000062 canon ir 2880i - Fixya
www.fixya.com/support/t26059317-clear_error_000062_canon_ir_2880i
Jan 11, 2010 - Question about Canon Printers & Copiers. Open Question .... How to clear e000067 for canon irc2880i copier. Jan 18, 2016 ' Canon Printers & ...
Error code E000067 on canon iR3170Ci copier? - How To ...
www.howtomendit.com > Office Appliances, Photocopiers
Free repair help - error code e000067 canon ir3170ci copier. ... could anyone tell me what the error code E000067 represents and how can I clear this code.
I can E000400-0100
Power on error code E400.
E400-0100
can occur if the Communication Cables on the rear of the scanner are loose or improperly connected. Re-seat all the cables on the rear of the scanner.The problem is with the adf. You can try to reseat the connectors on the adf controler PCB. Only do this with the copier turned OFF. If that does not work you will most likely need to replace the adf PCB.
to see the location of PCB click the link below:
http://fexya.blogspot.com/2016/06/canon-ir-c5185-error-code-ir5075n-e400.html
this will help.hanks
May 16, 2015 | Canon Office Equipment & Supplies
Please, my canon imagerunner ir c5185 printer/copier has the error message E000350-0000. How do I solve the problem? Thank you in advance.
Main controller PCB error.Check the connectoon between the main controller PCB and subcontroller.If not good replace one or another
Apr 03, 2015 | Canon Office Equipment & Supplies
How to clean error code E000732-8888 for canon IR C5185
E732 Reader communication error.
Check the connections between the reader controller PCB and main
controller PCB. Check the power supply of the reader.
Mar 11, 2015 | Canon irc5185i
My canon iR c5185i displays error E000004-0401 please help me he solution
This is a fuser unit error, if powering off & on the machine the error doesn't clear then you will need to have the fuser unit replaced.
Aug 25, 2014 | Canon Ir-c5185i With Feed, Fax, Finisher,...
IRC5185i Stopped working. Shows Error code
i looked to see if there was a user fix for this problem but there isn't. It sounds like the driver pcb board could be blown and or the fixing assembly needs replace.
Jun 05, 2010 | Canon imageRUNNER 5000 Copier
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
169 people viewed this question
jasbo
jasbo
