Question about Tefal ActiFry Deep Fryer
How to dismantle tefal actyfryer - Tefal ActiFry Deep Fryer
I am after a stopper for a Tefal soup maker,can you help
Hello, Kalonian -
The answer to your question as to where you can puchase a stopper for your Tefal soup maker depends upon the country where you reside.
Apparently, Tefal Repair Centers sell replacement parts for Tefal products.
First go to this web page:
http://www.tefal.com/country-selector
Select the country where you reside and click on the language link for that country.
Scroll down to the bottom of the Tefal home page for your location and choose Repairs. On the Repairs page, you should be able to find a Tefal Repair Center not far from where you reside (I hope), which you can contact to find out they can sell you a stopper for your soup maker.
Fixya.com receives questions from people all over the world, often making it a challenge to figure out the right information to provide.
Best wishes.
Jan 18, 2018 | Tefal Kitchen Appliances - Others
We have a tefal ironing station and it has developed a fault the steam is continually on and the green light is continually flashing can u help
The problem is caused by a blockage in the steam regulating valve. try the 50:50 vinegar solution as described above, If this does not work then you need to take out the valve and clean. IT is pretty simple. Remove the bottom of the base station and you will see a rectangular box with tubes coming out of it. This is the steam valve. Dismantle and clean and you should be good to go. whole job should only take 15mins
Mar 24, 2015 | Tefal Irons
How do i dismantle a actifry mixerblade
Hook it using a finger from the centre of the paddle, or use a teaspoon. It should slide off the mounting posts easily. Don't use anything sharp, or prise it from where the silicone and plastic are tight together, as it may get damaged.
Jul 09, 2012 | Tefal T-FAL FZ700251 Actifry Low-Fat...
I lost the manual for the Tefal DO250D34 food processor. can anyone help me find on online?
Tefal reports this as their food processor, although they don't list D0250D34 anywhere. Here is a link to the only user manual Tefal has across all of their sites around the world...
http://www.tefal.com/NR/rdonlyres/6D99133B-88A6-4BF1-8A71-780B49A7AC74/150/KALEO_eng.PDF
Jan 28, 2010 | Tefal Food Processors
Tefal aquaspeed 260 No heat no light. Fuse OK
I had the same problem. Turned out to be dirty contacts on the thermostat, easily cured with a strip of sandpaper, but you need to dismantle the iron first.
  • Remove the 3 Torq screws in the heel plate (the purple triangular bit at the back, that you stand the iron up on when it's cooling off). One of the screws is a security screw so you'll need a special screwdriver, though I suppose you could risk drilling it out if you're desperate.
  • Prise off the bottom section of the heel plate, to reveal the cable connector block. Pull out the connector block (it's just a push fit).
  • Pull out the self clean / steam selector button.
  • Prise off the white plastic front cover (the one under the self clean button, that surrounds the jet spray nozzle).
  • Under the cover are 3 screws that hold the sole plate and iron body together. Undo them.
  • Now you should be able to separate the main components of the iron and get to the thermostat. Check the contacts - mine had a build-up of carbon from the arcing as the thermostat operates. Clean both faces with a strip of sandpaper, then reassemble the iron, being careful to align the temperature selection lever correctly.
Dec 22, 2009 | Tefal Irons
Dismantling a Tefal program 8 400
Did you ever work out how to get the casing off??
I managed to drop my iron on a dodgy angle and some of the plastic casing has popped out and I don't want to force it back in when it clearly needs to be opened and put together again in the correct alignment.
If you know how to open it past the 3 screws, please tell....Thanks
Oct 06, 2009 | Tefal Irons
How to dismantle a Tefal Aquaspeed 150
no, its not the Aquaspeed 170, but Aquaspeed 150. i succeded to unwrap the housing, but did fail in disconnecting or dismounting the power cord terminal.i could not disassemble the Iron to reach the heater. to dismantle, step 1 unscrew 3 visible screws. step 2 lift the heel cover away, by unsnapping 1 hooks at the right and one at the left side of the heel cover. i used thumnbnail to deform the heel cover for not to wear out the snap-in hooks. step 3 remove the dischalk stick (don't know the right wording in english) step 4 lift the top cover (which covers the spray jet part), 2 hooks at both left and right, use thumbnail or flat screwdriver, start at the top hook. step 5 take off the spray and steam buttons, 1 hook at the front side, 1 hook at the outer back side step 6 take off 2 screws: one keeps the upper half of the handle, the other fixes the water container at the heater plate. Attention: when unmounting the container, and turning the iron upside down, a small (4mm diam, ~10 mm length) silicone cylinder part will fall out, some kind of actor of a bimetal thermo switch in the ground plate, which probably controls water flow (not the electric thermostate) so far so good, i got my problem solved, but would like to know how to disassemble the container from the ground plate and how to replace the cable?
Apr 12, 2007 | Tefal Aquaspeed 170 Iron
Tefal ActiFry Deep Fryer Logo
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
