Question about Shannon Dobson Godinger Ingrid Crystal 6 Piece Martini Set
Top of martini shaker stuck on crystal base, how do i remove
Someone removed the plastic insert from the stainless steel top of the shaker and then joined the top to the crystal shaker, but at an angle. I cannot separate the two...help
How to replace the stainless steel braded supply hoses for the hot and cold on a kitche faucet grohr
shut off water supply knobs remove hoses with pipe or crescent wrench at the base of the faucet under the sink and knob connections
Jun 28, 2012 | Grohe Home
Dishwasher has straw stuck in it
remove the lower basket and the filter, have a look in the base for the straw, if you can't see if feel around, if you still can't find it you will need to get someone to dismantle the dishwasher to remove it. it could be in the wash pump or in the drain pump.
Mar 10, 2012 | GE GLD4560NSS Stainless Steel Built-in...
How to clean maytag stainless steel finish on appliances
HOW TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do not use abrasive or harsh cleaners such as window sprays, scouring cleansers, flammable fluids, cleaning waxes, concentrated detergents, bleaches or cleansers containing petroleum products on plastic parts, interior and door liners, or gaskets. Do not use paper towels, scouring pads, or other harsh cleaning tools.
How do I clean and care my stainless steel surfaces such as refrigerator or any other stainless steel made appliance?
NOTE: Just because a cleaner is a liquid does not mean that it is nonabrasive. Many liquid cleaners designed to be gentle on tile and smooth surfaces still damage stainless steel.
> Avoid Citric acid
-it can discolors stainless steel. To avoid damage to the finish of your stainless steel appliance, do not allow these substances to remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS.
If you want to clean safe and keep the sparkling steel you can purchase STAINLESS STEEL WIPES this wipes is ideal for cleaning food spills,grime and stains leaving surfaces shining like new. This wipes is for stainless parts only make it sure this stainless steel wipes to come into contact with any plastic parts.BUT THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH CLEAN WHITE CLOTH.
Jan 26, 2011 | Maytag Refrigerators
How to remove spots on stainless cause from removeable protective plastic
The best and most inexpensive way to clean stainless steel is to simply dampen a lint free cloth with olive oil and wipe down the stainless steel piece.
Dec 24, 2010 | Maytag Dishwasher
Is the film on a stainless steel refrig supposed to be removed
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Apr 09, 2010 | GE Profile PSW26P Stainless Steel Side by...
The pump works but fails to shut off. The fill
If the fill valve does not open then there should be no water to pump unless the machines pressure switch is stuck in the closed position
That would fool the machine into thinking that the machine was up to level
Remove the back of the machine , look for a thin rubber or plastic tube going from the bottom of the drum to a small flying saucer shaped object near the top of the unit
Take the pipe off at the base and blow into it , you should hear a click , when you remove the pressure you should hear another click, if you do then the switch is working mechanically.
Turn the machine on and with the pipe still removed and see if the pump is still running if it is it is then you need to check out the pressure switch and the programmer
Mar 14, 2010 | Viking 24 in. Professional Series VUD040...
Cold water dispenser blocked
remove the tap if possible, insert a short length of flexible curtain wire to remove blockage, Pour boiling water into the reservoir and allow to filter out of the tap to remove sludge ect.
Sep 12, 2009 | GE Profile Arctica Stainless Steel Top...
Stainless Steel Cover for Grill
Yes the parts are available .As for the removing the material left on the cover,I would use a very light 400 sandpaper first to see if that makes progress.Without seeing the cover it's not advised to give any advice, only because without the right pressure and tool used it will vary on how this will be removed.
Jun 24, 2008 | Thermador PCS484GGUS Gas Cooktop
Shannon Dobson Godinger Ingrid Crystal 6 Piece Martini Set Logo
607 people viewed this question
Top Shannon Dobson Home Experts
Donni Steen
Tom Chichester
Are you a Shannon Dobson Home Expert? Answer questions, earn points and help others
