Question about Provo Craft Crafts & Hobbies
Calabration How do i calabrate my machine after I have been using it
  • 6982 Answers
SOURCE: TRANSMISSION
sounds like either a bad speed sensor or controller. shift points are too high, should be at 2000 or slightly less. if fluid is good and clean and shifts do not flair, check those control units. Not sure about calibrate...could mean out of calibration...Id ask
another tech about that. (i don't know everything!)
Posted on Mar 12, 2009
  • 111 Answers
SOURCE: frigidaire range model #fgfl67dcf needs to be
OVEN CALIBRATION Set the electronic oven control for normal baking at 350°F. Obtain an average oven temperature after a minimum of 5 cycles. Press CANCEL or CLEAR to end bake mode. TEMPERATURE ADJUSTMENT 1. Set EOC to bake at 550°F. 2. Within 5 seconds of setting 550°F, press and hold the bake pad for approximately 15 seconds until a single beep is heard (longer may cause F11 shorted keypad alarm). 3. Calibration offset should appear in the display. 4. Use the slew keys to adjust the oven temperature up or down 35°F in 5°F increments. 5. Once the desired (-35° to 35°) offset has been applied, press CANCEL or CLEAR. Note: Changing calibration affects both Speed Bake and normal bake modes. The adjustments made will not change the self-cleaning temperature.
Posted on Jun 18, 2009
ozztech
  • 285 Answers
SOURCE: HOW TO CALABRATE A ZEBRA P430i
go to the driver and send the command !SA
Posted on Nov 12, 2010
  • 14 Answers
SOURCE: The Tony Hawk shred controller
Hi, try using two old batteries with two new ones, also put the board on a small stool whilst calaborating, this worked for me after two goes, we also have a very tiny room and didnt move any furniture out of the way, hope this helps, good luck.
Posted on Dec 28, 2010
midnightdt
  • 60 Answers
SOURCE: lost calabration card
Im sorry to hear you have lost your Kinect Calibration card.
If you are unable to find it, you may purchase a new one for only $0.99 directly from Microsoft at the link below
http://store.microsoft.com/microsoft/Kinect-Calibration-Card/product/B7A7A3B2
Posted on Jan 18, 2011
My toshiba e studio 350 machine toner is very high.how could adjest devoloper and toner ratio please help.
05 turn on copier hold for 5 sec will go to test mode 200 print will start developer calabration going down in numbers adds less toner go down about 50 in numbers so it wiil stop adding then press set this is done all on touch screen except for 05 and 200 use keypad
Feb 07, 2013 | Toshiba e-Studio 350 Copier
Tachometer barely goes over 1000 rpm when i rev it up . at idle the car appears dead on the the tach
Sounds like your tack need calabrated, Sorry this is different on most tac's if possable try to get the model # and call your parts store and ask how you calabrate that certin tac, Good luck.
Mar 31, 2011 | 1994 Toyota Paseo
My nintendo dslite will not calabrate
maybe the touch screen is defective. did you drop the DS somewhere?
if you do the calibration REALLY fast, it may be able to correct the problem
May 15, 2009 | Nintendo DS Lite Console
CALABRATION
to calibrate your compass you need to goto an empty parking lot and drive around in circles until it starts displaying the directions
Mar 12, 2009 | 1995 Jeep Grand Cherokee
CALABRATION
to calibrate the compass goto a parking lot and and drive around in a circle several times until the compass starts working properly again.
Mar 12, 2009 | 2001 Jeep Grand Cherokee
Ds lite out of line
i dont get you that much
Jan 18, 2009 | Nintendo DS Lite Console
G5 Mac with a GeForce FX 5200
This is only a calibration issue. Your monitor is fine. and the card is fine. I would go to your displays preference and go to calabrate your monitor again. This time just choose the calabration from the default one. Ask someone else if they can see the box you just put on there. Sometimes it helps to have a second set of eyes.
Dec 17, 2008 | Apple Power Mac G5 Desktop
Convergence Problem
Perfect focus in these sets are dependant on factory or service mode calabration. once the unit is calabrated then those setings are stored to be the basis for perfect focus. The fact that you can manual converge the set is a good thing. probaly nothing phycially wrong with your set. However. what is needed is to get a qualified tech to look at your set and to calabrate the convergence.
Mar 04, 2008 | Zenith IQC50H95W 50" Rear Projection...
Hi, my t.v. is a Samsung rear projection and has what I can only describe as a "double picture". Had a repair man out yesterday who said it is not worth repairing as the message "no sensor...
A double picture to me is an indication of a convergence issue; from what you describe. WHat is the model for this set...i would have to know to be sure.. NO SENSOR data sounds like to me that the convergence has been messed up. No sensor data ussally means that the unit has lost calabration and will have to calabrated by a service tech... although these set are notourous i wouldnt give iup yet
Mar 04, 2008 | Televison & Video
Crafts & Hobbies Logo
52 people viewed this question
Top Provo Craft Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Provo Craft Craft and Hobby Expert? Answer questions, earn points and help others
