Question about Seiko Smart Label Printer 100 Thermal
Can Cymo lables be used in the Smart Label Printer 100
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 70 Answers
If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
Posted on Feb 28, 2015
SOURCE: I have a Smart Label 100 printer that won't print.
WHEN THIS HAPPENED TO ME, I DELETED THE PRINTED AND REINSTALLED IT...
Posted on Aug 20, 2009
  • 19 Answers
SOURCE: IM TRYING TO INSTALL SMART LABEL PRINTER 100, I
hi there..
could be the autoplay feature is not enabled... on your computer..
so in this case... click on my computer.. you should find ur cd drive specified.. double click on it.. .and please look for the .exe file..
how ever if you load it.. please check the requirements..
hope this helps..
  • 232 Answers
SOURCE: how do I export from outlook to my seiko 440 smart printer
I'm not familiar with this printer but usually you export details as a .csv file which you can import in to most other software packages. If you need more help, please can give more detail. Thanks :)
Posted on Dec 12, 2009
rulds2008
  • 3866 Answers
SOURCE: My smart label printer 100
This skipping could be caused by a roller not turning causing the paper to be forced to much into the thermal.
Repair is quite difficult the unit would need to be taken apart and the feeder investigated. You could put some machine lube on the roller part, but its quite involved.
Another reason could be the module inside not working correctly causing it to print like it is.
If you update me with additional info I could be more of a help to you.
Regards,
Rulds2008
Posted on Jul 21, 2011
SOURCE: Smart LabelPrinter Seiko 440
These printers are designed to use only the labels with the ink bar on the back. the ink bar is the guide that tells how much to print.
Posted on Oct 24, 2011
How do I transfer saved labels from Smart Label Printer 100 to Smart Label Printer 620?
In the SmartLabel directory under Program Files look for a file named label.sll This file holds your SmartLabel 100 addresses. After installing your new SmartLabel printer, copy the label.sll file into the new SmartLabel directory under Program Files. When you open the SmartLabel software, if you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Feb 27, 2015 | Seiko Smart Label Printer 100 Thermal
How do I copy smart label printer files from desktop to laptop
I'm making the assumption that your SmartLabel printer was installed on your desktop computer and now you want to use the SmartLabel printer on your laptop. I'm also assuming your what the addresses from your desktop computer. That said...
Seiko has eliminated the software and driver support for all older models but you can download the needed software from a third party site. Here's a link to the very stable version 4.61
Seiko SLP 100 Free Driver Download
Make SURE your SmartLabel Printer is NOT Connected!
Set Up Steps
A. Install SmartLAbel Printer on your laptop
1) Copy the Seiko software onto your laptop and begin the installation program.
2) At the point were the installation program asks, connect your SmartLabel printer
3) If the SmartLabel program is open, close it
B. Retrieve your SmartLabel addresses from your desktop
1) Look for the SmartLabel directory under Program Files on your desktop computer
2) in this directory find a file named label.sll This file holds your SmartLabel 100 addresses.
3) Copy the file to a USB Stick
C. Transfer your labels to your new installation on your laptop
1) After installing your new SmartLabel printer on your laptop. Insert the USB Stick in your laptop
2) Copy the label.sll file into the new SmartLabel directory under Program Files.
3) Start the SmartLabel software and open a new label, you should see the addresses from your desktop computer
4) If you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Hope this helps
Sep 28, 2014 | Seiko Smart Label Printer 100 Thermal
Seiko smart label printer 100 not printing
A censor within the printer probably needs cleaning.
Apr 08, 2014 | Seiko Smart Label Printer 100 Thermal
I have a Smart Label Printer 100 that I haven't used in 8 months. I tried using it again and I cannot get the power to come on. I tried to plug in to several different outlets with no luck. Not sure why it...
Sounds like there's a problem with your AC adapter. If you have another Identical AC Adapter (same connector, output voltage and amperage), try it with your Smart Label Printer. If it works its your AC Adapter. You can confirm the fault by checking its output voltage and amperage with a multimeter
Jan 29, 2014 | Seiko Smart Label Printer 100 Thermal
My printer appears to be printing the lables but
Make sure you are using thermal paper roll and not regular label roll.
Oct 05, 2009 | Zebra TLP 2824 Thermal Label Printer
I have a Zebra 160s lable printer & i want its installation S\W
You can use software such as Label Matrix, BarTender, EasyLabel or ZebraDesigner (free on zebra.com).
Jan 17, 2009 | Zebra Z4Mplus Label Printer
Jan 16, 2009 | Seiko Smart Label Printer 100 Thermal
Set up
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
It is explained in the user manual.
Mar 17, 2008 | Toshiba B-SV4D Label Printer
Zebra 4m
If you are in rewind mode and don't rewind the printer will pause while the rewind spool tries to catch up.
Jan 10, 2008 | Zebra Z4Mplus Label Printer
Seiko Smart Label Printer 100 Thermal Logo
Top Seiko Office Equipment & Supplies Experts
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
