Question about Skype IM
How do i go to settings on Skype,i want to check my microphone settings?
    New Friend:
Re install new window
Posted on Feb 23, 2014
I am having trouble getting the other person to hear me on skype
Try to determine if the microphone is working, check the microphone driver is installed and working.
Check the Skype audio setting and that your microphone has been selected.
Oct 02, 2012 | Toshiba Computers & Internet
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
Can I use a plug in microphone to use skype on a Dell precision M70
I haven't set up Skype before, but it seems quite reasonable that if the Sound control panel is set to use the external microphone, that would work. Have you checked to see if the sound input is set to an internal microphone built into the laptop, or a line-level input? That could be your problem, especially if no such microphone is present.
Nov 25, 2011 | Computers & Internet
When on skype the person i am calling cannot hear me but i can hear them
It sounds like your microphone settings may be incorrect. Make sure if your computer has an internal microphone that the settings are set to use the correct device. You can check in the Skype preferences.
If you have an external microphone (one you must plug in to the computer) try testing it on another computer to make sure it has not malfunctioned.
Aug 14, 2011 | Skype IM
My micphone seem not to work on the other end can you help.
Dear sylvers11
There are many cause for your microphone is not working.
1)if there are some hardware problem in your microphone than solve it from electrician.
2)check your microphone setting in pc.enable audio input .check you installed audio driver or not.
3)if all things is ok than problem is in your skype.check your skype setting.try skype test call services.
4)reinstall your skype if above tricks not work.
Feb 10, 2011 | Skype IM
When i skype with my granddaughter, i can hear her, but she cant hear me
It must be with your mic or with your computer's sound settings or with your skype sound settings. First check your Microphone, you can record something using the Windows (if your o.s. is windows xp or vista, or etc..etc..) built-in Sound Recorder.
Open your computer's sound settings and make sure it's default recording device is Microphone and the volume is turned up.
Open the skype, click "Tools", then "Options" and again click" "Audio Settings" and check the mic volume, if possible uncheck the "Automatically adjust the microphone settings" and turn the slider to the right. Save the changes you've made and try again.
If the problem persists, let me know.
Good luck.
Thanks for using FixYa.
Sep 17, 2010 | Skype IM
My microphone won't work. I can't hear my voice.Toshiba Satellite
Check which microphone device u have set up. Try changing it around. Also try just speaking closer to the microphone and into the mic. Some mics just are not good.
Aug 04, 2009 | Toshiba Satellite P105-S6104 Notebook
My internel microphone doesn't work with Skype -
You need to check the Microphone setting in Skype.
Open Skype, Click on Tools - Audio Settings, then in Microphone settings click the down arrow and select the built-in microphone then save the settings.
If the microphone you selected doesn't work then select a different one.
Jul 04, 2009 | ASUS W5Ae PC Notebook
Microphone not working
Hello.
1. Audio settings all versions
Skype:
Skype-->Main window…..>Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard (AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
2)Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted!
They sometimes stuck.
For test only you can use earphone instead of microphone for Line In.
Standard micro in Line In will NOT work.
Go to:
Start
Programs
Accessories
Entertainment or go to
Volume Control; right click on loudspeaker icon in Task Tray
Options
Microphone
Scroll down
Check "Microphone"
If the bar "Microphone" is available, the microphone is detected by Windows now go on
(If not, Windows has a problem with your microphone)
Just to check if your microphone is broken or bad, you can use your headphones instead. They really work!
Which one L or R is microphone now, I think it's L
Check "Advanced properties"
Check Micro "Advanced"
Open
Check "20db boost" or "1.MIC boost" depending on language version
Volume level can be left in any position.
Mute microphone!!!
3. Check audio now on windows base.
Start
Programs
Accessories
Entertainment
Soundrecorder
4. Once done, test with Skype Test Call echo123.
Good Luck
Please Vote.
Jun 17, 2009 | Dell Dimension 3100 PC Desktop
Microphone does not work
Yes, sometimes Skype messes with your hardware settings and sets it up to what "skype thinks works best", if you have System Restore turned on, try going back to the time before you installed that version of Skype.
Also, look in your Device Manager settings for anything screwy.
Dec 15, 2007 | Dell Latitude C400 Notebook
Skype IM Logo
32 people viewed this question
Top SKYPE Computers & Internet Experts
Mike
LP
Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
