Ptac suburban dynaline doesnt heat
Our Suburban Dynaline 3 has a period (.) in the display and we don't know what this means. I have tried to track down the manual, but cannot track down any troubelshooting or servicing documentation. Any help would be appreciated.
  • Julie Sullivan
    Julie Sullivan Jan 06, 2015
    Nope, I think we ended up unplugging and plugging it back in. There was a sticker on the inside panel that said how to reset it, and I believe we tried that, but the unplugging is really what worked.
    We also have a heater/air conditioner unit, not a microwave oven. Not sure why it is categorized here.
I had the same issue with my unit - I just needed to clean the air intake filter. The system will lock-down if it isn't getting the right air pressure / overheating.
It's easy to do, you just grab the lower back sides of the cover and lift it up and away from the unit. The filter is at the front of the system and can be pulled up and out for cleaning. You can then clean the filter with water / soap water.
There are also instructions in the manual about checking the flame - you can do this while the filter is off. There's a little window into the burner and you should be seeing a predominately blue flame.
http://www.scribd.com/doc/12278321/Suburban-Owners-Manual-DL3-0712-to-1622#scribd
Posted on Mar 01, 2015
We're you able to figure this out? We have the same unit and when heating it locks-out and displays a little dit next to the temperature.
Posted on Jan 06, 2015
Testimonial: "After this was happening and the air conditioner wasn't able to cool below 68, we had a handy man replace the compressor."
  • Nana
    Nana Jan 06, 2015
    By the way, ours is a heating unit and not a microwave
2004 suburban. Sun roof is stuck open and move about 1/2 inch back and forth. How do I get it closed?
If it is moveing in bolth derictions that means everthing is basicaly working .The switche's the motor ect. The problem is most likely xxxx is in the track that its sliding on .try to clean from the top of the vehicle . Its likely not in the front of the track but in the rear so clean what you can see mabey a little WD 40 in the track open close don't force the motor gentally move back and forth while clearing any debrie as you go .And clean the rubber seals and contact points
Mar 17, 2015 | 2004 Chevrolet Suburban
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
I have a 1994 chevy suburban i'm trying to find the 'service code' when i 'jumper' the A to B plug under the dash. it says the service lite will 'flash 1 time for one problem, 2 times for another and so on...
You have to count the number of flashes then check the repair book to see what it means. The sequence will continue to repeat, so don't worry if you don't get it the first time.
Dec 12, 2010 | 1994 Chevrolet Suburban
When I press the button to adjust heat all the little arrows keep blinking and i cant adjust the heat. What could be the problem? 1994 Chevrolet Suburban AC/Heating
The controller is dead. I have been trying to locate one for a 93, I haven't had any luck yet.
If you find a couple let me know.
Good luck
Randy
Nov 09, 2010 | 1994 Chevrolet Suburban
2003 suburban starting problems
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
May 29, 2010 | 2003 Chevrolet Suburban 1500
Heater not heating on 2002 suburban fan blows just does not heat up any ideas culd it be a relay switch
No, Relays control the fan running. But you said it is running. Low coolant level, clogged heater core or sticking temperature door could be the problem. Is the engine running at normal temp? Open thermostat could cause low temperature.
Feb 05, 2010 | 2002 Chevrolet Suburban 2500
2003 Suburban---Heated leather seat problem
there may be a software issue, there is a reprogram for seat heater issues. Bulletin 05-08-50-008 may pertain to that, a AC DELCO Shop or the dealer can ck that and see if this bulletin applies.
Sep 29, 2009 | 2003 Chevrolet Suburban 1500
Heating & Cooling Logo
354 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
