Question about Konica Minolta DiMAGE Z5 Digital Camera
Camera does not start even with new batteries
LCD screen is dark, even after pressing on-off switch several times and loading and reloading the new batteries several times
    Top Expert:
  • Konica Minolta Master
  • 6,702 Answers
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Posted on Feb 15, 2014
2 Suggested Answers
  • 72 Answers
SOURCE: Shoots blank (dark) pictures after switching on.
This is a known design defect in the cameras and Sony is repairing them, even if your warranty is expired.
see this for Konica Minolta's official statement:
http://ca.konicaminolta.com/information/20070202/01_en.html
it'll direct you to a sony page where you can sign up to get your camera repaired!
more info can be seen here:
http://www.dyxum.com/columns/other/First_Black_Frame/First_Black_Frame.asp
Posted on Nov 16, 2007
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
LCD screen started getting fuzzy, then went dark.
You have inserted battery in your camera after splashing water onto it. Switching ON the device caused short in the circuit. It needs to be send for service (repair), there is no other way to fix the problem.
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
Won't power on even though i've installed new batteries. There is no corrosion on the battery terminals.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
After replacing batteries, calculator is restored to defaults and screen display may be too loght or too dark
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Nov 14, 2009 | Texas Instruments TI-86 Calculator
I just put new batteries in my calculator and when i turn it on the screen is fuzzy and dark what is wrong?
Probably nothing is wrong. Decrease the darkness of the screen
1.Press [2nd] key and release it
2.Press [ArrowDown] key and release it.
3.Repeat the two steps above in sequence until screen lightens up. You may have to repeat the cycle several times.
Hope it brightens your calculator screen and your day also.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
Dark and blurry
It will clear instantly with a fresh battery.
The viewfinder screen has an LCD overlay and even when the camera is switched off the screen uses a small amount of power. When the batteries are flat the screen is unpowered, the crystals in the LCD align randomly to both darken and blur the viewfinder image.
Please don't forget to rate my answer.
Jul 18, 2009 | Nikon N65 35mm SLR Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Konica Minolta DiMAGE Z5 Digital Camera Logo
49 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
