Question about Motorola Mobility H710 Bluetooth Headset
Can't open battery cover
Need to change battery.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
I suggest you use plyers to open it. I hope I helped! :D
Posted on Feb 13, 2014
Cannot open battery compartment to change battery's
All you need to do is slide the battery cover to the Open position, then open the battery cover to access the batteries. If it doesn't open easily you may have some corrosion on the batteries holding the cover closed.
Mar 01, 2016 | Casio Exilim Ex-fh20 20x 9.1mp Digital...
Hoe to change galaxy tab batery
I do not believe it is all that easy to take the back cover off. Depending on which model of the tablet you have you need special tools. A plastic picnic knife might be helpful but then there are a couple of screws to open as well.
The different models have slightly different process. See these sites.
Samsung Galaxy Tab 10 1 Battery Replacement
Samsung Galaxy Tab Battery Replacement
Samsung Galaxy Tab 2 7 0 Battery Replacement
Sep 02, 2014 | Samsung Galaxy Tab Tablet PC
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
How to change key fob battery in 2010 mazda cx 9?
I just figured out how to change the battery in the Advanced (keyless) fob for my 2010 Mazda CX9. You just need to take out the physical key, and use a small flat-head screwdriver to pop off the back cover. Then there is a black battery cover with an o-ring that just pulls up to reveal the CR-2032 Battery. Here are some pictures to explain better:10_10_2012_2_13_28_pm.jpg
Jul 10, 2012 | 2010 Mazda CX-9
I need to change the battery of my watch and i don't find the place for removing the back cover
some watches have a notch that comes out where you can get a knife, or exacto blade underneath to pop it open. if not, there may be multiple intends along the ridge that would require a special tool to twist open. any jewler could change the battery for you. also, batteries plus stores can change the battery out at a reasonable price.
Aug 15, 2011 | Callaway CY2058 Sport Series Watch
I need to change my batteries and do not haVE A MANUAL
Battery is at the bottom. Open the cover at the base and slide it and it will pop open.The battery is there and you can replace it.
Take care.
Aug 12, 2010 | Logitech Cordless MouseMan Optical
How to change batteries on ku916aa
1. There should be a cover on the bottom with a release lip the batteries are here to replace. this is located right below the on/off button.
May 29, 2010 | HP Wireless Optical Mouse
I have a Microsoft Bluetooth Notebook Mouse 5000 and i need to change the battery. I cant find any latch or button to open the mouse to put new batteries in it! I looked on the MS site and found nothi
There is actually no release button on my 5000. Between the white on-off button and the bluetooth synch button there is a finger notch. If you put your index finger in the notch (pointing toward the base of the mouse you can put your nail under the lip and the batter compartment opens right up. There is a horizontal slot in the battery cover - trying to pry that open does not work. The whole thing is well-cloaked but surprisingly easy when you figure it out!
May 27, 2009 | Microsoft Bluetooth 5000 Mouse
Change battery
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 12, 2009 | GE Optical Mini Mouse ho98094
Change the batteries cover
I'm not an expert by any means, but that does seem like the way to take it apart and fix it. I have the same camera and the same problem. Where did you find a replacement cover for your batteries? Thanks & Good Luck! Free Eagle
Jun 07, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Motorola Mobility H710 Bluetooth Headset Logo
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
