Question about Motorola Mobility H710 Bluetooth Headset
Open battery cover
How to I open it to change the battery
Cannot open battery compartment to change battery's
All you need to do is slide the battery cover to the Open position, then open the battery cover to access the batteries. If it doesn't open easily you may have some corrosion on the batteries holding the cover closed.
Mar 01, 2016 | Casio Exilim Ex-fh20 20x 9.1mp Digital...
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Mar 31, 2014 | Weiser Lock POWERBOLT ELEC DEADBOLT
How to change irulu ax922 tablet battery replacement
The most Irulu tablets have 2 small cover screws on each side, pop the cover unscrew it and open with careful. the battery is connected inside its a square white plastic cover connected to the motherboard . Hope this help.
Mar 20, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
Change battery in wireless mouse?
yes - change them - there is a screw cover - unscrew the retaining screw - Philips screw type - and replace the batteries
Dec 08, 2010 | Logitech Cordless Mouse
When I key in the pin it says to proceed but the bolt wont open. do I have to change the batteries? If so, how do I change it? My safe is a fire safe S0607
Locksmith advice on how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 10, 2010 | Sentry Fireproof Safe
How to change batteries on ku916aa
1. There should be a cover on the bottom with a release lip the batteries are here to replace. this is located right below the on/off button.
May 29, 2010 | HP Wireless Optical Mouse
How to change the battery
the metal cover will be sliding and if you will slide it left or right battery should come out.
Thanks
Nov 25, 2009 | Kenneth Cole KC2315 watch
Cordless mouse refuses to open so I can change the batteries
Underneath the mouse on the same end ad the battery cover should be a small slide with an arrow, push the slide and it should release the battery cover
Apr 08, 2009 | Logitech Cordless Mouse
Change battery
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 12, 2009 | GE Optical Mini Mouse ho98094
Motorola Mobility H710 Bluetooth Headset Logo
194 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
