Question about Sharp EL-1197P Calculator
Sharp calculator is rounding the answer - Sharp EL-1197P Calculator
What does the 5/4 and F mean on the display screen?
F is for floating decimal. If you do a calculation, it will present the results without rounding. For example, 1/2 would be displayed as 0.5, whereas 1/8 would be displayed as 0.125.
The 5/4 rounds the results. For example, if the number of decimals is set to 0, 1/2 is 1. Similarly, if the number of decimals is set to 2, 1/8 is 1.3.
Good luck,
Paul
http://support.casio.com/en/support/answer.php?rgn=5&cid=004001001004&qid=32&num=1
May 21, 2016 | Sharp EL-1701C Calculator
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
I divide numbers that dont go evenly into each other and it rounds the answer to the nearest whole number. how do i stop this?
Press SETUP and and choose 1 for FSE. Then choose 3 for NORM 1. This should fix your problem.
If all else fails there is a reset button on the back of the calculator.
Feb 10, 2014 | Sharp ELW535 Calculator
HOW DO I REMOVE DECIMAL FROM MY CALCULATOR BECAUSE IT KEEPS ROUNDING MY ANSWERS
If you have the manual for the calculator it should tell you there. If you dont have it you maybe able to download it for free that should tell you how to remove the decimal point.
Sep 25, 2012 | Sharp El-531x Scientific Calculator Green...
EL-531X I NEED TO GET IT TO QUITE ROUNDING MY ANSWER
Hi Jennifer,
This may be because of your settings. To change them press SET UP, then select 0 for FSE. Press the down arrow and choose 3 for NORM1 - the calculator should now stop rounding off your answers.
I have a problem with my Sharp EL-531WH Scientific Calculator. It rounds off the answer. In my Chemistry class, we need exact answers. For example, an answer of 0.234 must be the answer if that's the...
Press the [SET UP] key, followed by the 0 key to bring up the display menu. You can select "FIX" followed by the number of digits to the right of the decimal point, or press cursor-down and select one of the NORM modes. Press [ON/C] to exit the menu.
Be aware that some numbers cannot be displayed exactly. For example, 1/3 is a 0.3 followed by an infinite number of 3s.
Jun 25, 2011 | Office Equipment & Supplies
It keeps adding up to one decimal place...I want exact calculations. How do I do that???
You must have accidently set the calculator to round your answers. To fix this, click the MODE key, scroll down to FLOAT, and click ENTER.
Mar 03, 2011 | Sharp EL738C Scientific Calculator
How do you change the number of decimal places?
• Press [2nd] [MODE] and scroll to FLOAT.
• Press the right arrow key until the number of decimal places needed is highlighted.
• Press the [ENTER] key.
For 2 decimal places, 2 should be highlighted. All answers will then be rounded to 2 decimal places.
• Press [2nd] [QUIT] to return to the home screen.
Mar 17, 2010 | Sharp EL-738 Scientific Calculator
Reset to factory settings
remove battery and return it back this make reset-decimal places can be adjust with decimal switch.
Dec 21, 2007 | Sharp EL-240SB Calculator
Sharp EL-1197P Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
