Question about McCulloch Garden
No oil getting on to the chain on my mcculloch but the tank is full
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Check the chain oiler, and adjust it with a screw driver.
Posted on Jul 03, 2016
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Posted on Apr 24, 2009
  • 42 Answers
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
Posted on May 17, 2009
  • 4088 Answers
SOURCE: need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: mcculloch em300s electric chain saw stopped oiling
This is a little complicated so I’m going in small steps.
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Electric Chain Saws” The model number of your saw is probably on a tag affixed to the bottom. The tag also displays the serial number.
If it is a 300S the hyphen is the bar length.
I looked at the 300S-16 (same oiler parts as -14)
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Item 15 has a filter on the bottom check it first, insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). If good I’d look closely at item 17. I can’t get enough detail from the IPL but that is the logical culprit.
Oil systems on all Mac Electrics appear pretty basic. Good Luck
Lou
Posted on Nov 09, 2009
  • 78 Answers
SOURCE: Chain oil tank full, feed
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Posted on Nov 15, 2010
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
Oil level in motor of 3200 mcculloch chainsaw
This a 2 cycle engine where fuel oil is mixed with the gasoline. The mix is 40:1. If you attempt to run straight gas in this engine you will destroy it as would using regular oil.
The oil tank on this saw is for the lubing the chain and needs topping off every so often as you use the saw so that the chain stays oiled.
With the original McCulloch manufacture being out business parts are very hard to come if you can even find them.
Dec 03, 2014 | McCulloch 3200 Bar & Clutch Cover
Oil leak mcculloch electramac em250 ?
You have a cracked tank, or busted chain oiler. Will have to take apart to view the chain oiler , and check if oil is puddling just under the oil tank. There is some epoxy sealers, or gas tank stop leak material that can possibly repair the busted or leaking oil tank.
Jul 19, 2014 | McCulloch Garden
This old mcculloch chainsaw has 2 tanks 1 fuel and 1 oil. do iuse 2cycle oil?
You need to use a 25-1 fuel two stroke oil mix in the fuel tank, the oil tank is to lubricate the chain, here should use a non fling chain oil.
Jun 20, 2012 | Garden
McCulloch 14" chain saw Model CS 38 EM It quit
Most often there is a dust-oil clog in the bottom of the bar slot which closes an oil passage between the bar slot and the hole drilled half way through the side of the bar. This provides a passage between the thin shim plate with the two bar bolt holes beside the bar and through to the oil tank or pump output. You can remove the bar and chain and punch out the blockage in the bar with a paper clip if the chain is removed. Make sure the wire can be pushed from the bar slot right through the side hole in the bar. A gravity feed chainsaw should leak right out into the slot of the shim plate, a button pumper should squirt out there with the bar removed. With a button pumper you may have a tiny check valve in the line or the push button to take apart, replace the spring or unstick the ball inside the check valve. This is why they went to the gravity feed oil system which just leaks in there and gets picked up by the bottom of the links as the chain races past the passage between the bar side hole and the chain slot.
Mar 23, 2011 | McCulloch Garden
I have a Mcculloch electric chain saw model 235 for which is not pumping oil onto the chain. Can you please advise where I can purchase a new oil pump Regards Darryl.
This is a full strip, and split side covers to get to the pump, this may well be a job for the local repair agent, having been apart it should then be PAT tested to ensure the double insulation it still good.
Mar 20, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
WHAT KIND OF OIL DOES THIS USE?
Chain oil ( non fling ) in the oil tank, and a 50-1 fuel oil mix in the fuel tank, only use good quaility two stroke oil designed to run at 50-1, preferably oil produced by a reputable chainsaw manufacturer.
Feb 27, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Not getting any oil on the chain and the oil is full
Remove the bar and chain--clean the cover and case side. Start the engine and see if oil oozes out of the side port where the bar fits. Also, try the manual oil pump if it exists. If ok, clean the bar end oil-passages including the two channels that run from the large holes out to the chain groove on each side of the bar. Clean the entire chain groove, and check the tip sprocket for free turning. If no oil came out of the port, then remove the rear case which exposes the two tanks, the oil pump and the bracket that holds the bar to the engine. The oil pump runs by use of crankshaft impulses and has a diaphragm in the pump body that may be damaged. Also check the tank filter fitting. When you get everything back together, run the bar tip at speed near some cardboard--it should throw off a thin line of oil after several moments of fast running. Hope this helps!
Jun 19, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Garden Logo
57 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
