Question about iLive iCP360 Color Changing Clock Radio With Dock For Iphone / iPod
Setting the clock and time
Need instructions or manual
RCA Model RP3765 manual
Hi Arlene, Your clock should actually set its own time if the two Double batteries are installed. If not click link and follow instructions RCA RP3765 User Manual Setting The Clock Setting Clock
Good luck
Nov 04, 2014 | Audio Players & Recorders
Manual download
Here's a link to the manual for your clock: http://timexaudio.com/media/uploads/product/files/T307_IB56281_07.pdf
Dual alarm settings are on page 8, and I've included the specific instructions below. I would think that the '5' setting would be for Mon. - Fri., but let me know if that's not correct. Hope this helps!
"After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week (7), weekdays only (5), or the weekend (2). Before setting the alarm, be sure that the correct date is set, as shown in the "Auto-Set" and Manual Time and Date Settings section of the manual. While the display is still flashing, press the Date/7-5-2 Button until the desired setting is shown."
Dec 17, 2013 | Timex (T307S) Clock Radio
Www.lacrossetechnology.com/8248 need to reset time!
I'm not totally sure what you mean by "reset the time" because the unit normally sets the time automatically from the WWVB radio time signal. If you want to do it manually, this is what the Instruction Manual (PDF format) says:
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
  1. The hour digits will start flashing in the upper LCD.
  2. Select the desired hours by pressing and releasing the + key.
  3. Press and release the SET key to advance to the minutes setting.
  4. Now the minute digits will start flashing.
  5. Select the desired minutes by pressing and releasing the + key. If the + key is held, the units
    will increase by 5.
  6. Press and release the SET key to confirm the Time setting and continue to the Year setting.
Nov 08, 2012 | La Crosse Radio Controlled Atomic Clock
Panasonic =iv NV-MV40 , how to set the clock please
You can download the user manual for free from the Panasonic website.
Apr 03, 2011 | Televison & Video
Setting clock or get copy of manual/instructions for the entire clock/ipod dock.
Setting the clock:
1. Press the set button 3 times until all of hte digits for the main clock are flashing.
2. Press the Skip Forward and Back button for the hour and the Volume Up and down for the minutes.
3. Press Set button once to confirm and exit the setting menul.
Call 866-387-2027 for manual
Oct 14, 2009 | Starlite Next Play Clock Radio with iPod...
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
Apr 07, 2009 | Microwave Ovens
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
Pioneer DEH-P3000IB operations manual
How to set the clock on the DEHP3000IB?
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF] (power/source button)
Pres & Hold [Muti-Control] (big button that controls volume) until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segment.
Mar 16, 2008 | Car Audio & Video
iLive iCP360 Color Changing Clock Radio With Dock For Iphone / iPod Logo
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
