Question about Car Audio & Video
Kaption amplifiers The speaker cut out on 4 channel 50.4 model but does not always happen
5 Suggested Answers
SOURCE: Left Front Channel Goes in and Out
left channel there is a problem use a tester to locate the bad transistor
Posted on Sep 18, 2007
caroldon
  • 17129 Answers
SOURCE: Alpine 3530 Bridgeable 4 channel power amplifier
Use the left and right to connect the positive and negative to the respective speakers in the right and left. Please make sure of the polarity and so be cautious. next you can connect the sub woofer from the left and right channel as the amp is bridgeable. Use the lead to connect from the R- positve to L negative. test and check the phasing of the speakers, must get good low bass or else you can reverse the sub woofer and check again. If you ae having frint speakers connect accordingly the the other channel. Helpful Good day
Posted on Jul 13, 2010
SOURCE: front right speaker got wet, started cutting out.
front left channel humming sound
Posted on Apr 07, 2011
  • 689 Answers
SOURCE: Which speakers (Front/Rear) to buy that match Kenwood KAC-M846 4/3/2 Channel Amplifier.
I don,t no where you are reading thease articles from,I installed car audio equipment for over 40 years, Untill i retired a couple of months ago, Who ever is writeing those sort of articles does not have the slightest clue what they are talking about, It is the opposite way around, It is allway better for yor (Speakers) To handle more power then what your amp puts out, Then you will not blow the spaekers, It is best to get speakers at least 20 watts more then what your amps maximuin (RMS) Watts are, Hope this helps you out, (PS) 50 watts (RMS) Is what most people go for, It is in no means (Under) Powered.
Posted on Nov 06, 2012
Testimonial: "Rob cleared the cloud of confusion and shared his wisdom and expert know how about car audio amps and speakers."
Rear left channel makes my speaker pop cuts in and ou at certain settings
Swap left and right speakers. Does it stay with the speakers if so you have a blown or damaged speaker. If not then swap input cables only. If it stayed with the speaker you now know the amp has a bad channel and needs repair. If it swapped again you either have a bad cable or issue with your source unit.
Jul 26, 2016 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Speakers cutting in and out at high volume
The amp is going into protect on the two channels powering the speakers. Turn down the gain on those two channels. You also may want to consider crossing over the speakers a little higher than they are now.
The rating on those speakers are way too high. 6.5's and 6x9's will take 50-100 clean watts tops before they start to break up.
The best solution to get it perfect is....unplug the subs. Turn the gain on the speaker channels all the way down. Then turn up the deck 80% as high as it will go. Play a song. Then increase the gain on the amp until the speakers are as load as they go without distortion. Shut off the car, replugg in the subs and do the same thing. Gain on sub channels all the way down, deck then to 80%, find a bass heavy song, then turn gain up until subs become distorted. If you do this procedure your speakers and subs will be "gain matched" to the proper levels.
Good Luck
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
Nov 05, 2012 | Kenwood Kac-m846 4/3/2 Channel Amplifier...
I have a Technics SU-V460 integrated amplifier, and the left channel (speaker) keeps "dropping" out . I have to turn the volume right up in order for it to "kick" back in. Would this be...
There are three possible problems with your system. The first, and cheapest to fix, is that the wire connecting the left channel is faulty. To test this, unplug the wire from the back of the amp and put a new one in, then play some music BEFORE putting everything back into it's respective place. If the speaker doesn't cut out anymore, problem solved! Speaker wire is very cheap too. If the problem persists, try connecting one of your other speakers that you know works to the input. If that speaker cuts out as well, then the amplifier is the faulty component. That will cost some money to repair (between $50-$150 depending on where you go, excluding the price of a new amplifier). If the speaker you know is not faulty works when plugged into the left channel, then the only other option is that the original left channel speaker is faulty. This could cost between $25-$100 to get repaired, excluding the cost of a new speaker. It will not be as costly as a new amp, but will definitely cost more than a new speaker cable.
Mar 03, 2011 | Car Audio & Video
What does it mean when the red IND PROTECT light is on? my subs cut in and out, mostly out with the occasional hard hit popping up in the middle of a song. Whats wrong?
You've got the gain to high and the amplifier is clipping the sound frequency causing it to distort. Possible problems are you have a bad speaker(s) and the reading is below 4 ohms. Each of the 4 channels can only take 4ohms. If your bridging 2 speakers to this amp you have to also make sure you are only bridging 4ohms anything lower will cause the amp to overheat. Dont put 2 speakers in parallel on one channel or you will definitely have more problems.
Apr 07, 2010 | Pyramid 1000 Watt 4 Channel MOSFET...
My Peavey Mark 3 400 CHANNEL 1 does not put out sound. When you turn the pre gain it will cut in for a sec then out. Channel 2 is good. I checked the readings on the pre gain pot on channel 1 and 2 and...
Transfer Channel 2 speakers to Channel 1 to check if it does put out a sound. If it does, it means that your Channel 2 amplifier is defective. However, if it doesn't,
then your Channel 2 speaker is defective. So, have this checked to find out the result. Defective items needs replacement or be repaired. Send us your e-mail for the result so we can further extend our assistance.
Oct 13, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
May 25, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Sep 16, 2007 | Alpine MRV-F357 Car Audio Amplifier
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
