Question about Virtual Reality Sound VR3 CD Player w/ USB and Scan Disk Inputs
Vr3 when playing dvd error message wrong region
CHANGE the REGION on my SONY DVD BDP-S185
From the users manual:
Region code (BD-ROM/DVD VIDEO only)
Your player has a region code printed on the
rear of the unit and will only play BD-ROMs/
DVD VIDEOs labeled with identical region
codes.
Nothing was said in the manual about changing the region code.
Jan 28, 2014 | Toshiba D-VR3 DVD Recorder/VCR
Why does it say wrong region when trying to veiw a dvd? on model vrvd630
because it is locked to a region, check menu for region settings and adjust to region. 4 is australia
Apr 20, 2010 | Virtual Reality Sound VR3 CD Player w/ USB...
DVD player is saying "Wrong region"
region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
Jan 01, 2010 | Insignia Televison & Video
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Nov 23, 2009 | HP Pavilion dv9000z Notebook
Wrong region
how do i get a movie to play i can hear the sound but no picture
Sep 03, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
How to change region code on Toshiba D-VR3 player?
1) In DVD mode,press System Menu.
2) Go down to the Lock icon.
3) While lock is highlighed, press 0 for seven times (o,o,o,o,o,o,o).
4) There will be a pop-up window that asks you to confirm.
5) Press ok.
Jay
May 21, 2009 | Toshiba D-VR3 DVD Recorder/VCR
BUSH DVD2038
hi i'm trying to change region so i can watch can you help
Nov 13, 2007 | Bush DVD2038 DVD Player
The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
-Ed
Mar 31, 2007 | NAD C541 CD Player
Car Audio & Video Logo
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
