Question about Asko D3251HDSS Stainless Steel Built-in Dishwasher
Asko dishwasher bad control board with burnt component at the 5dv terminal
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: re:communication board
http://www.samswebsite.com/ goto this site hope this helps.
Posted on Nov 11, 2007
  • 351 Answers
SOURCE: Control Board bad
most of the time there is a schematic behind the kick plate or the door skin but it wont tell you the value or the resistors.but theres normally another cause for the board to blow.is the rinse aid leaking into the door skin,or wires starting to break in the door.the boards are normally sold complete.I work for asko and find the boards dont normally fail by themselves.hopt this helps.
Posted on Mar 23, 2008
SOURCE: Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Posted on Jul 24, 2008
SOURCE: need asko dishwasher d1776 control board #8801201
http://www.guybanks.com/asko/products.asp?category=3
Control Board Kit Part # 8801201 Price: $319.95 Shipping: Free*
Posted on Dec 23, 2011
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
A lot of water spilled over the sink and some got probly inside control panel of my ask Asko dishwasher machine. Machine doesn't work properly after. Pump is always working and impossible to stop or r
If you getting power to the machine, it's likely you did not blow the internal fuse unless there are two. They are white, about an inch long thick as a pencil with metal ends. The other would be damage to a canister on the smart board. Take it out with power off and look for a burnt spot in the solder. I your see it, you have two choices. Repair It with solder, or replace the smart board on line for about $150.00.
Jan 13, 2015 | Asko Dishwashers
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
Asko D3530. Program LED does not come on. Also nothing happens when I push Set, Menu or Start. Tried button on the left (cirle with a I, looks like a reset button?). Checked plug, GFI and circuit breaker...
Welcome to FixYa.
It sounds like you've got a bad power switch or a wire at the power switch or as you described it... (circle with a I, looks like a reset button?) that's the power button, this will require removing the control panel, but I'd check the power at the dishwasher first though...
You'll need to check behind the kick plate at the bottom as opposed to just checking the GFI and circuit breaker. This is something I've seen fairly often with Asko dishwashers.
**Use caution when checking voltages with a live circuit. Turn off the breaker when servicing the unit otherwise...safety first**
If you have any reservations or aren't completely confident performing these tasks I suggest calling in a pro, sometimes the $100 or so is worth it.
You'll need a volt meter or multimeter to check for voltage as well as to look for burnt up connections at the terminal block/junction, it'll be pretty obvious if present. This will indicate a wire has been loose and burnt due to resistance, simply cutting it back and refastening it securely should solve the problem provided no further damage was done.
Let me know what you find and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Asko 24 in. D3530FI Built-in Dishwasher
I have an Asko Model 1585 and the detergent door will not stay shut and there is a constant noise coming from the door like a selonoid is stuck open. I turned the unit off at the breaker for fear of a...
Welcome to FixYa.
Based on the description you posted..." detergent door will not stay shut and there is a constant noise coming from the door like a solenoid is stuck open " You are bang on...unfortunately.
This is a red flag. In these scenario's 99% of the time the control and Combi-dispenser are both at fault. The control is no longer available according to the "repairclinic.com" website, but they have this note...
**Control board kit *Note: Consumers can contact Asko at (800)898-1879 option 3 for further assistance.**
The buzz you hear is indeed the solenoid for the dispenser, the control is sending voltage to the soleniod all the time.
If the component has failed both will need to be replaced, you can inspect and check the dispenser with an ohm meter and visually inspect the control board.
Having said this, If you remove the door and control panel and visually inspect the control you will most certainly see burnt circuits, relays or resistors on the control. i.e
**Be sure to turn the power off to the dishwasher before servicing...safety first**
The associated output components on the control unit for the dispenser to check are as follows,
Combi dispenser... Q12, R50, R58, D21, D23, P2 3 ( these are identified this way on the control unit. )
The last available control part number is # 80 579 31-4 and a good control if you can find one, should resemble the image here...
As for the dispenser, the original Asko number is 88 011 39-77, but now subs to 1399543 and is available at "repairclinic.com" It will look like this, front & back...
Hope this info helps move you forward, I know it isn`t a lot of good news.
Let me know what you find or if you require further assistance. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 27, 2010 | Asko 24 in. 1585 Built-in Dishwasher
Di9shwasher will not go througt whole cycle
Step1:
Step2:
If ur dishwasher doesn't starts then first check the usual suspects. Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Step3:
Asko dishwashers have problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced.
Apr 03, 2010 | Asko 24 in. D3120 Dishwasher
Control Board bad
Mar 22, 2008 | Asko 1595 Dishwasher
Asko D1796 will not start properly
It sounds as if you may have A bad control board. It could be causing the heater element to come on when its not supposed to (usually a stuck relay) and not filling the machine with water. you could also have a bad control board AND a bad fill valve, as a stuck relay for the heater shouldn't affect the fill valve circuit. The bad news is that these asko control boards are $350 to $450 for just the part, the good news is that the control board is under a 5 year warranty (for only the part, not the labor to change it) as are the pump motors and any timers. Also, if you are just out of warranty, find your date of installation, as asko warranties start when you install it, not when you buy it (if you moved into the house and it was there when you moved in, and you are the first owner, submit a date of occupancy and that's when your warranty started)
Jan 01, 2007 | Asko D1796FI Built-in Dishwasher
Asko D3251HDSS Stainless Steel Built-in Dishwasher Logo
21 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
