Question about Rayovac Camping, Backpacking & Hiking
How do i put battery in my flashlight?
Cannot get it to close
How to put batteries in flashlight
Ah, a 'flashlight'. I changed the category from Cameras for you. You said 40429t0ss 340 in last post :>)
What is the type of battery? Make and model of flashlight?
Reply by way of comment below my post
Dec 05, 2016 | Camping, Backpacking & Hiking
Utilitech flashlight. How can I replace battery?
  • Open battery compartment
  • Remove old battery (or batteries?)
  • Install new battery (or batteries)
  • Close battery compartment
  • Check operation
Mar 08, 2015 | Camping, Backpacking & Hiking
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
I cant open the tonka flashlight force fire truck to put in a new bulb
Take out batteries and undo the two screws in the battery compartment by about two full turns.
Remove the two screws in the underside between the front wheels.
Use a thin blade and slide it in to recess at top of lens between silver trim. Prise out lens top carefully as there is a retaining flange on the lens and you don't want to break it.
Rotate top of lens forward and it levers out of the bumper.
Its a screw in bulb.
Reverse steps to close up.
Mar 10, 2013 | Camping, Backpacking & Hiking
I just bought the coleman Max mult-colored headlamp and i cant figure out how to put the three AAA batteries in
In the headstrap is a plastic 'key' that you use to remove the battery cover (opposite side of the headlamp from the switch). Once you remove the cover, you can shake the headlamp to let the battery cartridge slide out of the headlamp.
Pay close attention to which way the batteries go in--if you put a battery in the wrong way you can easily bend the springs inside!
Oct 26, 2010 | Coleman 3AAA LED Headlamp
Batteries got corroded in the flashlight now I can't get it out. How can I get the battery out?
If you can remove both ends of the flashlight, find a piece of pipe that is slightly smaller in diameter than the inside of your flashlight, hold the flashlight body in one hand and the pipe in the other. place the pipe on top of the batteries then strike the pipe on a heavy hard surface that you are not worried about damaging. The blows should dislodge the batteries. Clean the corrosion thoroghly before putting new batteries in
Jun 14, 2010 | MagLite Mag-Lite& Flashlight
What way do i put the battries into a maglite
Place the batteries positive (+) end first into the flashlight tube and continue putting other batteries, again positive first. Good luck!!
Oct 11, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
Apr 05, 2009 | Stinger Streamlight 75000
Camping, Backpacking & Hiking Logo
55 people viewed this question
Top Rayovac Camping, Backpacking & Hiking Experts
jmcpoyle
Level 1 Expert
Dave Reilly
Level 1 Expert
Are you a Rayovac Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
