Question about Numark Industries Numark CDN88 PRO DUAL CD PLAYER FOR DJ USE
What laser is in CDN 88 pro - Numark Industries Numark CDN88 PRO DUAL CD PLAYER FOR DJ USE
  • 1,815 Answers
Its looks like a SONY brand with KSS laser 213c .
Posted on Jul 01, 2016
No sound third octave on korg trinity pro x 88 keys
After gaining access to the inside- carefully remove the ribbon connectors (plugs) and reseat them. If that doesn't help have a tech. look for bad op amp.
Jan 11, 2015 | Korg Music
No sound third octave on kong trinity pro x 88 keys
You have a dislodged/dirty/broken ribbon connector coming from the keyboard. If you're not experienced in the disassembly and repair of your instrument, take it to a service center.
Jan 11, 2015 | Music
One cd player wont read
Take a can of compressed air and blow into the player all around and try it. The heads get dirty over time and stop reading. Clean the dust off the laser head and they usually start working again.
Feb 28, 2013 | Numark Industries Numark CDN 22 Mk4 Double...
3 keys that are around black center c are not working at all.
The contacts are most likely dirty. Did you spill something on that area? If you are handy, open the keyboard and clean the contacts. You can use a q-tip with rubbing alcohol. Being a controller, there shouldn't be too much wiring inside, but take note of which connectors you disconnect.
Apr 28, 2011 | M-Audio New M-audio Pro Keys 88 Stage...
The external speakers attached to my m audio prokeys 88sx are no longer working. I have replaced the fuses in both but the fuses blow on power up. I then used the keyboard with a set of headphones. One of...
It is NOT likely the keyboard is "killing the speakers"... OR the headphones for that matter.
I suspect the problem is bad switch contacts in the headphone jack that cut off the speaker line outputs when headphones are plugged into the pro keys. These jacks are, to put it bluntly, JUNK... they are EASILY damaged by pulling the cable plugged into them sideways. You will need to service the unit.
Jan 16, 2011 | M-Audio Pro Keys 88 Premium Piano
Howe do i reset the Pro Keys 88 to factory settings?
Here is a site:
http://www.m-audio.com/index.php?do=support.faq&ID=5157184a3df533e664f6dfaef620d6b2
Essentially you hold down the + and - buttons while powering on the unit. Hold them till it is obvious it is resetting.
Nov 15, 2010 | M-Audio Pro Keys 88 Premium Piano
My child jammed something inside of my keystation pro usb connector.... Broke the copper connectors inside.... Whats the best way t go about this ... replace the entire piece or soder in a new copper line
If the traces are lifted, then use jumpers to the points of origin of each trace. Tack the jumpers down with silicone seal or other adhesive.
Replace the connector ifthere is any chance of damage to the connector itself.
Oct 14, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
My behringer ub2442fx pro has the numbers 88 flashing red in the display and a clicking sound every time they flash. any idea what the problem is?
A high likelyhood of a power supply problem.
I had a similar thing on a GX110 and it was an electrolytic cap that filters for the 5 volt regulator on the DSP board.
As the DSP starts up, the load on the supply sucked it below the operating point and caused the DSP to keep reseting. The display did flash.
The unit will have to be opened and trpunbleshooting done to find and repair the problem.
Dec 20, 2009 | Behringer Music
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Numark Industries Numark CDN88 PRO DUAL CD PLAYER FOR DJ USE Logo
21 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
