Question about Dell Wireless Keyboard Optical Mouse w0147
How to change battery in wm123 mouse - Dell Wireless Keyboard Optical Mouse w0147
My mouse, a dell wm123 wireless optical mouse, stoped working, changed the bateries and all i can get is a faint green blinking light.
You can not fix a defective mouse. I suggest you go to Walmart and get a new combo wireless keyboard/mouse for approximately $20.00.
Jan 16, 2018 | Dell Computers & Internet
I have a Dell optical mouse WM123. Mouse works fine initially. When there is screen lock and I enter Windows username/pswd, I get the message that device driver has failed. Anyone faced this problem?
A workaround might be to go to Device Manager and under USB Controllers, Properties of each USB hub, Power tab, deselect the "Allow Windows to turn off this device to save power" option.
But to solve the problem, you probably need to update the driver for the mouse, or revert to an earlier driver under mouse properties in the Control Panel.
Jun 12, 2015 | Dell WM123 Wireless Optical Mouse
Are you sure that the "new" batteries are good? If they are good you may have aproblem with the USB part or the proper mouse. Test it with some computer dianosis application lik AIDA65
Oct 13, 2014 | Dell WM123 Wireless Optical Mouse
DRIVERS FOR THIS
It's a plug and play.
u may be connecting the receiver to a USB port that is overloaded.
try different USB port, or disconnect some usb devices and try again
Apr 16, 2014 | Dell WM123 Wireless Optical Mouse
How to fit cell into dell WM123 wireless mouse
consult the operation manual if you havent discard it yet, look at the bottom
Nov 29, 2013 | Dell WM123 Wireless Optical Mouse
Does mouse have a battery? I cannot get the mouse to work.
All cordless mice have batteries. Usually you'll find a battery door on the bottom.
Jul 15, 2010 | Logitech Cordless Mouse
How do I change the battery?
  1. change-wireless-mouse-battery-1.1-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.1-800X800.jpg'); });
    Flip your mouse over and remove the battery cover. Gently pull it up and set it down in a safe place.
  2. Step 2 change-wireless-mouse-battery-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.2-800X800.jpg'); }); Carefully remove each battery.
  3. Step 3 Insert the new AA batteries into the mouse. Make sure the positive and negative connectors are lined up correctly. Do not force or jam your batteries into place.
  4. Step 4 Place the battery cover over the opening and click it into place. Flip your mouse over. If your particular mouse has a charged or not-charged display light, make sure it is showing full strength.
Mar 14, 2010 | Logitech Cordless Mouse
Changing batteries on a logitech lx5 mouse
turn off the mouse using the switch on the bottom.
press the battery door release button on the underside of the mouse, towards the back.
that should release the battery door, which is the top part of the mouse, where your palm would rest.
the mouse takes 2 AAA batteries.
Feb 04, 2009 | Logitech Cordless Click! Mouse
Dell Wireless Keyboard Optical Mouse w0147 Logo
50 people viewed this question
Alun Cox
