Question about Onkyo TX-SR603X Receiver
Is the onyko tx-sr603x capable of being bi apmed?
SOURCE: TX-SR603X cuts off at higher volume levels
The overload board is failing.
Posted on Jan 30, 2007
  • 4234 Answers
SOURCE: Buzzing/vibration noise from ONYKO TX-SR506 unit
If the unit is under warranty, DO NOT open it up. Bring it in for an exchange or warranty service. Explain that the unit makes noise during use and it will be serviced. This could be as simple as a bad connection in the power supply area and you are hearing oscillations or it could be a defective power transformer. Either case will be covered under warranty so there should be no charge to you.
Keep us posted.
Dan
Posted on Feb 17, 2009
  • 4234 Answers
SOURCE: Power outage overnight. Now, Onkyo TX-SR603X no
Depending upon the type of power outage, you may have more of a confused receiver than a defecive one. Try unplugging the unit for an hour or so to see if that resets the whole thing back to "normal". If not, then further investigation with a scope or logic analyser will be required to determine whether the problem is with the internal CPU or a defect on the data lines. Unless the reset works, this is not likely to be a DYI repair.
Dan
Posted on Mar 28, 2010
Testimonial: "Appreciated. I'll try to "reset" tonight."
SOURCE: I have an onkyo receiver tx-sr603x. I can get
audio amplifier´s damaged need to be replaced
Posted on May 25, 2010
smarthome2
  • 1114 Answers
SOURCE: how do you reset the TX-SR603X receiver? Will that
Try thiThe most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps. s.
Posted on Sep 19, 2010
Terry, does the Grey go into the Red or White on the Onyko?
Hi Cardell, please email me at askOnkyo@us.onkyo.com. I will need to know the color of the cables you have so that I can advise you where to connect it on the Onkyo, Thanks, JT
Oct 11, 2015 | Onkyo Rc-251s Tx-sv303 Tx-sv313...
I have a Onyko TX-SR303 5.1 Receiver and sound is only coming out of left front speaker.
Could be the IC that controls the various sound/surround channel modes. Had that happen on my Pioneer receiver.
Charged me close to 200 bucks to fix!
Aug 24, 2017 | Onkyo TX-SR303 Receiver
How can I run a turntable through the onkyo tx-sr603x?
Look on the back of the system, if there is phono input, that is what you can use to connect the turntable without using an external pre amp
Aug 27, 2011 | Onkyo TX-SR603X Receiver
May 25, 2010 | Onkyo TX-SR605 Receiver
Dan
Mar 28, 2010 | Onkyo TX-SR603X Receiver
Onkyo TX-Sr603 goes back to standby when press On button - help!
does not sound like the fuse.
its easy to check. unplug unit and remove the cowling / shroud of the unit. the internal fuse will look like a car fuse. the old round style about 1" long and 1/4" round.
sounds like a bigger problem. hope this helps.
Feb 19, 2010 | Onkyo TX-SR603X Receiver
ONKYO AV RECEIVER TX-SR603X
When I initially bough mine, I had the same problem. It wouldn't shut down, but occasional popping sound on the center speaker. Turns out the impedance on the speaker was 4 ohms, not not 8. Replaced center with an o 8ohm speaker. This receiver is not reated to run 4 ohm speakers. If I had problems with 1, I can only imagine what kind of problems could happen if all the speakers were 4-ohms.
Oct 14, 2007 | Onkyo TX-SR603X Receiver
Onkyo TX-SR603X Receiver Logo
23 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
