Question about Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952
Our Kenmore Washer 500 will fill with water and then begins to agitate but the wash knob will not move. After starting a load before bed, we heard the washing machine come on again in the middle of the night. It smelled very hot so we let it cool down before attempting anything. After trying to do another load, the machine would not turn on at all. I was able to unplug the machine and plugged it back in and it started right up. I was able to do a full load of laundry without any problems but then just attempted to do my next load and again the wash knob has not advanced after some time. Any suggestions????n it appears to aggitate and begin a wash cycle but the wash knob will not move. The other night it sml
    Top Expert:
  • Kenmore Master
  • 43,059 Answers
This could be a defect in the timer, especially if it is the electromechanical type.
Posted on Feb 14, 2014
  • 641 Answers
SOURCE: front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Posted on Jul 23, 2007
  • 351 Answers
SOURCE: My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Posted on Jun 24, 2009
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 500 top load washer starts to fill withwater then stops
This is commonly caused by a lid switch malfunction. If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
If the lid switch is found to be defective, it can be purchased at any of the following websites:
searspartsdirect.com
applaincepartspros.com
pcappliancerepair.com
repairclinic.com
The average price is $25 to $35. Prices vary between these sites, so shop around for the best deal.
This is a very simple repair, but if you still have questions, please let me know. I hope this helps you.
Posted on Oct 06, 2009
  • 1937 Answers
SOURCE: Kenmore 70 Series Washing Machine Just Hums (Won't Agitate)
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22712100
Also see the Whirlpool / Kenmore service manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are a worn/broken motor coupler.
See the following for how to get to it and check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=6019c5e82bfa177df953f5d6ebeac983
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
It's possible that the prongs have broken and the humming that you hear is the pieces rubbing against the center rubber piece.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Jan 10, 2010
Testimonial: "Awesome - Thanks!"
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Kenmore 500 washer wont spin or agitate
Have you checked on the belt or belts that drive the tubs action?
Jun 21, 2012 | Kenmore 500 6952 Dryer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Fills up with water and shuts off...
    This information may help you to learn more about your washer.
    copy n paste
    http://www.partselect.com/MultiModels.aspx?ModelNum=RAS6233KQ&searchTerm=img_I3TR96FR&RefineSearch=0&imgMfg=Whirlpool
    becouse it was over load it may be out of balance becouse of the
    exessive weigh.
    "Did it solve your problem?"
    Apr 01, 2009 | Roper RAS6233KQ Top Load Washer
    Washer keeps filling with water...
    you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
    Jan 11, 2009 | Kenmore 22422 Top Load Washer
    Washer will not cycle
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
    Agitator not working 90 series model # 11026912691
    Hello aksward,
    Welcome to Fixya.
    Here are some suggestions for any Kenmore washers
    Let me know how it goes. I'm still thinking and searching my repair manuals!
    Huuum
    Please remember to leave a rating!
    KENMORE ELITE TOP LOAD
    Washer stops, won't fill, rinse or agitate
    • Check the following:
    Is the power cord plugged into a grounded 3 prong outlet?
    Is the indicator on the Cycle Control knob properly lined up
    with a cycle? Turn the Cycle Control knob to the right slightly
    and pull to start.
    Are the water inlet valve screens clogged?
    Are both the hot and cold water faucets turned on?
    Is the water inlet hose kinked?
    • Does the water level seem too low, or does the washer
    appear to not fill completely? The top of the agitator is
    much higher than the highest water level. This is normal and
    necessary for clothes to move freely.
    • Has a fuse blown or is the circuit breaker open? If problem
    continues, call an electrician.
    • Are you using an extension cord? Do not use an extension
    cord.
    • Is the washer in a normal pause in the cycle? The washer
    pauses for about 2 minutes during certain cycles. Allow the
    cycle to continue. Some cycles feature periods of agitation
    and soak.
    • Is the washer overloaded? Wash smaller loads.
    • Is the lid open? The lid must be closed during operation.
    Washer will not agitate or spin with the lid open.
    Oct 06, 2008 | Kenmore 22422 Top Load Washer
    Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952 Logo
    48 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
