Hello. I really need your help.I have WR514WD3 access point with three antenna but I don't have its manual and I couldn't configure it
    Problem Solver:
  • 14 Answers
Hello there, is it a TP-LINK router? If so it should come with a CD which will help you to configure it automatically.
Just boot the CD and connect your router through ethernet cable and the software will detect your router and help you configure it step by step. Hope this helps
Posted on Feb 15, 2014
3 Suggested Answers
  • 17 Answers
SOURCE: Trying to configue a 3com router as an access point
You have to configure the WDS on the 3comm, configuring it to the MAC ADRESS of the BT router (if it is wireless), if not connect it by ethernet and set the 3comm as WDS allowing the other 3 more u want to add as acepted MAC ADRESS for access points.
Posted on Feb 20, 2009
garethmt
  • 116 Answers
SOURCE: configure 6216mg as access point
No, not unless there is a WDS option in the Wirelesss setup. Only specific devices can do that.
Posted on Mar 26, 2010
Dlink external antenna configuration
Hi .In my Experience if you Change the Antenna Must be equal Both are Antenna Like 12 dbi Otherwise you are facing the Slow Issue.
must be same DBI Antenna (on my Experience 2700 AP I Face same issue ) when i change the Antenna both are Equal It s Fine working Thanks
Feb 04, 2014 | Computers & Internet
Need to replace the gear in my singer sewing machine model 288
I can't get you the full instructions but I can offer some ideas which may help you. When you get into the machine (if the timing is still good) use a white or yellow grease pencil and make a mark across both gears as a reference point... then take a picture. When you start messing with gears it's really easy to get the machine horribly out of time. The reference point and picture will help you keep from getting it so far out of time.
I don't know if this will help you but here is a manual for your machine. I couldn't find an adjuster's manual.
http://www.singerco.com/uploads/download/652_288-974-972-244-2405-588-875-1195-3130-3140.pdf
Sep 08, 2012 | Singer Sewing Machines
Can't configure netgear access point wg602
try to access the the router by using address 192.168.1.1, if this don't work then reset the router and used the factory setting in the manual
Mar 25, 2012 | NetGear WG602 802.11g/b Wireless Access...
How do you connect the antenna and get channels to work?
First make sure that your Input is TV. Use the Input button on the remote (to the right of 0) or on the side of the TV (lowest button). To watch OTA channels, after connecting the appropriate antenna for your location with a coaxial cable to your Antenna In port, press Menu then use the arrows to select the Setup submenu. Press Enter to access the submenu and select Installation. Then select Terrestrial and then Input Configuration. Here select Antenna as your input. Press Enter to save. Then scan for channels by returning to the Terrestrial sub menu and select Channel Program to scan all available channels.
Since digital signals are either sufficient for your tuner to interpret or give No Signal, you need to select your antenna and point it with care. Go to anntennaweb.org or tvfool.com to get information on the stations that you should be able to get in your location. Antennaweb assumes an outdoor antenna but still gives a conservative list of available stations. TVfool gives stations depending on the color code of the antenna (indoor, outdoor, amplified) and their directions. If you are sharing the antenna signal with multiple TVs, you may need an amplified splitter. (If you do have an amplifier, you may want to test removing it from the line and directly connecting the 37HL17 to the antenna. When amplifiers get damaged they can turn into signal filters which block the signal completely.)
If you have the correct antenna, check if another TV receives the stations. If so, you may have a bad tuner on the TV. (Some TVs have better tuners than others and pick up the stations even with lower signal strength.)
I hope this helps.
(I use an outdoor antenna and antennaweb indicates that I should only get the stations from 10 miles away. I actually get those from 30 miles away as well. When I set up a neighbor's TVs with indoor antennas, one only gets the stations 10 miles away and the other gets the stations that are 30 miles away. The two antennas couldn't be rotated to the same direction.)
Nov 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I can't get connected to the internet
I need more info to answer this, really..... But I'll suggest possible solutions...
1) Are you anywhere near your access point (or if you're using ur neighbor's internet.... -____-)?
2) Did you put in the right password if your access point requires a password?
3) To get a better connection, don't block your wii's antenna from objects...
4) Maybe your connection is too low?
Yeah... If you didn't know you need a wireless access point, then that's the problem...
I know this might've not really helped much..... you just have to specify things.
Mar 03, 2011 | Nintendo Wii Console
Antenna required to connect ap 530in 802.11a mode
The manual for this AP states "If both Radio 1 and Radio 2 are set to the IEEE 802.11b/g mode, Radio 2 must be configured to an external antenna."
802.11a mode is only supported on Radio 2 per the documentation.
Mar 29, 2010 | HP ProCurve 530 (J8986A) 802.11a/b/g...
I am trying to hook up a omni antenna to a wrt54g is it possible in a motel setting
Hi there If u have a linksys wrt54g router. the omni antena will not give u the maximum wireless signal if u are going to set it on a motel, u need to setup a wireless access point in order to broadcast the signal or to repeat the signal u need a wireless access point and the model # is WAP54G..
here is the link just incase u want to know more about on how to set up a wireless access point
1. How do I configure an access point as a wireless bridge?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4194
2. How do I configure an access point as a wireless repeater?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4200
3. How do I configure an access point as an access point client?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4202
4. How will I know if an Access Point is configured as an Access Point?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4165..
check this out and i hope this will solve ur concern..
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Have a problem with configuring router with computer
From user manual:
"When the Login pop-up for the Router
appears, please enter “admin” for the
username to access the configuration screen.
(Note: By default, there is no password. If
you cannot get in, please reset the router by
pressing the button next to the antenna on the
back of the router and try logging in again.)"
Follow instruction and let me know if you need a copy of user manual.
Jan 02, 2009 | Hawking Wireless-G HWR54G (603992506064)...
Stronger antenna
unscrew the antenna, and buy an rp-tnc connector and an n-male, then get an antenna with female n-type connector. LMR240 coax is better than RG58 for 2.4. which ever you use get the connectors to suit. Then crimp or solder them to your coax and away you go. no need for other settings ... just ssid of access point.
Oct 18, 2008 | EnGenius EOC-3220 (EOC3220)
Computers & Internet Logo
David Payne
David Payne
