Question about Konica Minolta Minolta FAX3900 Digital Copier, Copier/Fax Machine 16 ppm printing and up to 600 dpi resolution, rec... Printer
The paper only feeds half way through the feeder then jams on the fax machine.
  • Konica Minolta Master
  • 6,161 Answers
Clean the rollers with small amount of water and soap or replace them also check the path use a business card to push through the area where the paper bends to go under neath
have a tech come out hard to over the internet
Posted on Jan 18, 2016
firecontrol7
  • 6161 Answers
SOURCE: konica 7025 paper jam
Does this happen when he orginals go thur the document feeder? How does the copy look if the orginal is placed on the glass. Vertical feed problem mite be dirty rollers or dirty clutch,
Posted on Aug 17, 2009
SOURCE: Top ADF will not recognize paper in the feed tray.
Try to replace the 'paper is present' sensor with the 'cover open' one to see if now it is detecting the paper. Also, check the actuator that enter in that sensor.
Posted on Aug 23, 2009
komguy
  • 2306 Answers
SOURCE: Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Posted on Sep 02, 2009
Shah_Sheh
  • 81 Answers
SOURCE: magicolor 5440dl manual feed jams paper as it
If the paper was damaged we can presume that there is a blockage, however your jam sounds like the paper is not in the expected position at the expected time (ie a sensor is not reporting that a peice of paper has reached it) so this can be cased by
1. rollers slipping on the paper from
a/ slippy media - try a different paper (even as a test)
b/Build up of paper dust on the rollers- If you can see the roller, power off and wipe with cloth
c/ Roller ware - If you can see the roller and have a mild abreahisive like wire woll If you can see the roller and give the rollers a rub
2. Sensor failure-Try Powering off then unplug wait 2 minutes and then power back up, this will reinitilise a sensor
Posted on Sep 10, 2009
  • 79 Answers
SOURCE: At power on, my bizhub 222 immediately gives me a
If you have verified that there is no jammed paper, then I would suggest taking a can of compressed air and blowing the doc feeder out as best you can. Often times dust or paper scraps and debris can become lodged in the paper path, frequently blocking a sensor, thus creating a jam (despite the lack of paper.) As well, you might try running a thick piece of card stock through the feeder, as this will act to dislodge any stuck paper bits.
Let me know how it turns out.
David R.
Posted on Dec 11, 2010
CANNON MODEL D880 TOP FEEDER JAMS WHEN TRYING TO MAKE MULTI COPIES AND/OR FAXING...HOW TO CORRECT THIS?
Check to make sure that the rollers are in good condition inside the top feeder.
Also make sure that there is NO object or anything that the paper is hitting against by manually feeding the paper and carefully observe the paper path
May 03, 2011 | Canon Office Equipment & Supplies
Need replacement process for paper feed roller in scanner compartment.
On the doc feeder there are 2 arms that go down into the machine. UNPLUG machine first. You squeeze them carefully and rock the doc feeder backward. It may take some manuevering,
Once you have separated the top half of doc feeder, you will see a wire harness going into the upper half, CAREFULLY unplug it. There are several screws holding down the cover over the bottom half, remove them and again carefully separate this cover from the main body.
Once this is done you should be able to replace the feed roller. One note, while you have it this far apart you ought to change the separaetor pad in the top half.
If this helps you, please log in a vote for me, thanx
Feb 07, 2011 | Brother Fax-1360 Plain Paper Inkjet Fax
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
"check paper" error appearing
ON THIS MACHINE THERE IS PAPER FEED ROLLER THAT NEEDS TO BE REPLACED THE TOP HALF OF THE FEEDER MUCT COME OFFF TO DO THIS OR YOU MAY HAVE A SENSOR OUT OF WACK WHICH IS UNDER THE FEEDER. IF YOU ARE GOOD WITH HANDS YOU WILL FIND IT GOOD LUCK
Jan 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Paper feed not feeding properly
There is a gray rubber pad on the upper half of the feeder.
Take the white piece off and turn the pad 180 degrees.
Aug 28, 2008 | Samsung SF-560 Plain Paper Laser Fax
Paper Jam message
There are a couple of sensor flags in side the machine and also the document feeder area. Little black levers that flip and trip a sensor. Make sure they are all moving freely. There is one or two in the doc feed area. One inside the paper feed area. One or two in the ribbon area.
Apr 19, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
