Question about Honeywell Enviracaire 50250 Air Purifier
Honeywell 50250 air purifier turns on but fan does not work
It has power because the lights come on but the motor will not run the fan is there a fuse that can be replaced.
SOURCE: Honeywell 18155 Air Purifier
did you ever solve this issue? I just borrowed my mom's and it worked fine for two days and then suddenly won't turn on at all. I wonder if there is a fuse that might have blown during a power surge while we were out of town or something...
Any help would be appreciated.
Posted on Jan 03, 2008
  • 3 Answers
SOURCE: Can you tell me the
I am 99.9% sure that you are simply looking at this year vs. last year models. There are absoutly no significant changes. I will verify on Mondayas I know the engineer at Honeywell that works on this particular product!
Posted on Feb 01, 2009
SOURCE: my honeywell air purifier is emmiting an awful
Mine quit too... The led screen went blank so I changed the battery. Now it does nothing. I totally disassembled it as the fan was turning stiffly.(should spin very easilly) The grease in the end bearing was stiff. I washed the gummy grease off the shaft and reoiled with synthetic oil. Your smell is probably motor windings overheating. I disassembled the electronic control and was disgusted to see that there is a glass fuse soldered to the circuit board. I believe the only reason for this fuse is to cause us consumers to needlessly replace otherwise good equipment. (It cost more to pay a repairman to replace the hidden fuse than to purchase a new unit)The fuse is not blown. At least this fuse actually looks lide a fuse unlife the stealth fuses most electronics have hidden in them. I can not obtain a wireing diagram on my 17005 unit but it has a black box inside behind the control panel. It looks like a small start capacitor, but it has a temp rating on it of 70*C. I suspicion it is a single use over heat safety which triggered when my motor got hot due to stiff bearings. I refuse to play their game and purchase a new air cleaner. I love this one... So, if I can not determine what that little black box is, I am going to bypass all the crappy electronics and just drill a hole on top by the handle and install a hi/lo/off manual switch directly to the motors wire hasness. This machine will never give me problems ever again, and if I oil the motor every couple of years with synthetic (Ander oil) this unit WILL last me for the rest of my life...
Posted on Jan 02, 2010
SOURCE: honeywell air purifier, will not turn on,
Does this unit have a 3 volt battery in the control panel like the 17005 model? The battery lasts appx 4-5 years then the unit doesnt seem to work any more once you change it. The unit must be left plugged in while you change the battery otherwise you lose your programing. If your not under warranty, UNPLUG it then pull out the filter, take out the 6 screws, separate the sides, and expose the fan. If the fan does not spin very easilly with no drag, the bearings are gummy; which is why nearly all small motors get replaced. The motor can be easilly disassembled, gummy grease washed off with rubbing alcohol and a cotton swab, and reoiled with synthetic oil. These units are designed to gum up and require replacement at approximately the same time the warranty expires. They would last almost indefinitely if oiled in their little oil ports occasionally (every couple of years). If your bearings are stiff, then a hidden safety device has tripped to avoid a fire, and if you are handy, you can replace the blown fuse if you can locate it on the circuit board, or the blown over temp device. If you have to pay some one to do this, it is cheaper to replace the whole machine in this throw away world.
SOURCE: No operating instructions in Honeywell HHT-145 air purifier box
http://www.kaz-canada.com/kaz/support/manual/#Honeywell
All honeywell manuals are on this site
Posted on Mar 21, 2010
Why doesn't the fan engage? The filters are perfectly clean and it receives power
See if the motor is bound up. Move the fan blade to check for stiffness. The motor may just need a drop of oil. There is an internal fuse in the motor that you cannot change It may have opened. If you have access to a volt meter check all the wires on the power switch
Jul 16, 2014 | Honeywell 50150-N True HEPA Allergen...
Environizer doesn't work
Is it dead? does the motor run? Fan blow? No freshened smell from unit, only stale odor? You haven't given any usable info here but I'll address a dead unit condition for you: power cord stretched/damaged, on/off switch bad, fuse/cicuit breaker(if any are used).
Jun 15, 2014 | Air Purifiers
GE Adora microwave worked 20 minutes ago. Now, totally dead. The lights, fans, turntable motor, microwave cooking elements, nothing.. works. AC power to the outlet is just fine.
Sometimes if a lot of steam has been produced while cooking, water may collect under the turntable plate and run down the spindle into the turntable motor. This can short circuit the motor and it will take the fuse out with it.
The fuse is usually housed in a plastic tubular case about 2inches long. Split the tube apart and replace the fuse if necessary (it's something silly like about 7000 volts). Switch on and check to see if anything else is not working like the turntable, lights, or fan etc and replace as necessary.
Feb 16, 2014 | General Electric DVM1950SRSS 505 Adora...
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
Aug 07, 2012 | Honeywell 50250-S True HEPA Air Purifier
Fan is not coming on
The motor spins on brass bushings. you can try oiling the brass bushing. take off the front grill then gently pull off the fan blades. you need to oil the motor center shaft lay it on its back so the oil will run down into the bushing(not to much and use a light oil). there is one on the back of the motor also, this one is a little harder to get too. if this dont work you need a new motor. you can get on off of ebay cheaper. the motor should be replaced by some kind of tech savey person, as the are delicate and a very specifice disassemble procedure.
Jul 07, 2012 | Alpine Air XL-15 Air Purifier
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
My Honeywell Enviracaire Hepa Air Filter machine has a squeak when it runs. I am unable to find a place to oil it. Can you help?
is no place to oil it.They have closed type motors. You can just use a lubrificant typeWD40 to spray the mouving parts
Feb 21, 2011 | Honeywell Enviracaire 13520 Air Purifier
We have model 11502 air purifier. Recently turned it on and it ran for a few minutes and then stopped. Motor sounded fine- no squealing, didn't slow down before it went off- just stopped like it was...
Yes there is a thermal cutoff that will shut the motor off for a period of time to protect it from getting to hot. If this is what happened after 20-30 mins. the motor should come back on and run again. If it does I would try to clean motor as best I could using a soft brush, vacumn, and blow out with air if possible. Clean fan of f as best you can to help motor run cooler.Hope this helps.Thank you
Jan 05, 2011 | Honeywell Air Purifiers
Fan blade barely rotates when turned on high.
there may be a problem with fan motor,but i believe your problem may be the rotory switch that controlls voltage to fan motor,to check this pull knobs off front ,then remove filter from back,there are 4 screws in bottom of case remove these,pull unit out carefully .there are 5 wires conected to unit ,two for fan 2 for on off switch,1 for ground just what wires go were,then disconnect wires from there posts,and pull unit out of box,find the two wires that go fan,snip wires that go to the circiut board leaving enough space to rewire after test get extention cord and snip off to make direct plug to fan to wall connect extention to the two wires from the fan motor and wire nut or tape so no short,pug extention cord into wall outlet if fan runs on a high rpm or max power,then your rotory switch is no good and you can install an external rotory switch on side of unit,if fan does not run any faster then your fan motor needs replaced,let me no if you need more help
Dec 03, 2009 | Ecoquest Living Air Classic Air Purifier
Honeywell Enviracaire 50250 Air Purifier Logo
759 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
