Unlock code for dm100i - Office Equipment & Supplies
Remedy for "No ink tank detected"
Can be one of 4 probl0.
1. Bad ink cartridges
2. The gold pins that make contact withtthe ink cartridge are bent,happens a lot w withgeneric ink.
3. The print carriage is bad
4. The system boardis bad.
End users can only fix the first 2, the others should be covered by thepPitney Bowes warranty
Sep 10, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
How can I reset my pitney bowes ink cartridge
The ink cartridges should notbe reset or reused, rregardless ofwwhat some refill places tell you they are made for a single use & refilled ccartridges frequently leak or clog the lines in the meter.
If you are referringto the waste ink ttan, that can be reset using the tech code 6946 then press refill ppostag, go thru the menu todiagnostics, printer, page down & rreplace waste tank & reset. ONLY DO THIS IF YOU ACTUALLY REPLACE THE WASTE TANK.
Jul 09, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
I Can not see the screen on my pitney bowes dm100i?
Screen contrast probably needs to be reset which can be done by:
1. Unplug the power cord
2. Press the #4 AND KEEP HOLDING IT DOWN UNTIL METER IS FULLY started aafternext step.
3. Keep the 4 button pressed & plug the power cord in, while keeping the 4 button held down.
After meter fully boots the screen will be restored to normal if contrast settings were the problem.
If this doesn't resolve the problem, the screen or control panel is bad & should be replaced. This should be covered under yourpPitney Bowes warranty while meter is onlease.
Apr 29, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Postage meter is saying a connection cannot be made to call support
This frequently happens when the location uses digital telephone lines. The meter is more specific than fax machines and does not work reliably on any phonelline that is not true analog like an old home phone line before vonage & cable phone service.
Alternatively you can connect thru the Internetusing a usb cable and pc/laptop with Pitney Bowes pc meter connect software which is free on Pitney Boweswwebsite or the larger model meters can connect directly to a corporate networkwwithouta pc aas middleman.
Apr 01, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Change normal preset
Place a sample of normal mail youwwant to set default for on the scale, select proper class & other specific items, then press the custom presets button and select "Define nnormal preset"
It will ask if you want to use current settings, answer yes and after a few seconds you will be finished
Jan 28, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Wrong rate of .48 for normal preset.
48 cents is currently the correct rate for metered first class mail of normal size & weight. Using the meter currentlyentitles yyou to a discount
Jan 27, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Pitney Bowes P700 has a a blue screen
I just spoke with a service rep because at startup, our screen would completely fill in. To set it back to default, unplug everything and when you re-plug it in, hold down the 4 button until it's done Initializing. This should reset everything. If you need to adjust the contrast, hit the options button, then it will be the 3rd button down on the left and the top button will become 'increase contrast' while the middle button will be 'decrease contrast'. Hope this helps!
Sep 14, 2012 | Pitney Bowes Postage Meter DM100i, DM200L,...
Need mep number
Unlock your Blackberry 9530 by using a Blackberry IMEI Unlock code, also called Blackberry MEP unlock code. Here is a link to get Unlock code for Blackberry within seconds.
Excellent customer and technical support, and you can pay using Paypal or credit card by phone.
Hope this helps!
Oct 27, 2010 | RIM BlackBerry Storm 9530 Smartphone
I need my mep code for my blackberry curve 8520 imei 359428031689888 please really need to get it sorted ??
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your Blackberry 8520.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
Oct 15, 2010 | RIM Blackberry Curve 8520
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
13 people viewed this question
k24674
jasbo
jasbo
