Question about Mitsubishi Televison & Video
My model # WD-60735 Mitsubishi projection tv power light blinks green when I turn the tv on. Why?
We replaced the lamp recently and the tech told me the power light should not blink green when I turn it on. It is blinking green when I turn the tv on. Can you tell me why?
    Top Expert:
  • Mitsubishi Master
  • 75,581 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Posted on Feb 14, 2014
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
SOURCE: TV won't turn on.
Lamp is bad need new lamp
Posted on Apr 27, 2008
SOURCE: hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Posted on Feb 10, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Posted on Feb 14, 2009
  • 5 Answers
SOURCE: red blinking light when tv is turned off
if this is a 37lg30 i have brand new spare parts. the tv was never used it was dropped and the screen was damaged so i just took out the parts out. i was originally looking for some one that had a problem with there tv but a good screen like you but its easier to ship out the boards.
Posted on Jun 06, 2009
How do i reset the lamp timer on my mitsubishi model wd-60735
Not going to fix that if the set even has that (which I doubt). Was the lamp a Mitsubishi or a generic cheap replacement?
when set goes off look to see if lamp is off or on, If you have to turn set back on or when its off, do the sets self check--press and hold both the menu and device buttons at same time for 5 second and release both---power light should blink a digit error code like 1,2, blinks pause and repeat that (1,2 is no error found and 3,7 is lamp issue.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
May 18, 2011 | Mitsubishi WD-60735 Projection Television
How do you change the lamp in a Mitsubishi model WD 60735 projection TV
Try website like Youtube.com,search type in ur tv model,make and projection lamp replacement.U will have somebody,have a tutoring video doing it.
Oct 04, 2010 | Mitsubishi WD-60735 Projection Television
I have a mitsubishi wd-60735 tv when i turn the tv on nothing comes on only hear the volume and screen just pitch black?
Did you recently replace the lamp? If you did then it might be the new lamp. I mistakenly bought an aftermarket lamp to replace mine and it would not work consistently. Apparently if it is not an Mitsubishi original lamp it has issues, because after I replaced it with a Mitsubishi lamp it worked perfectly fine.
Aug 14, 2010 | Mitsubishi WD-60735 Projection Television
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
It just shuts off :(
replace Lamp Call Mats Electronics 1-800-628-1118
Feb 01, 2010 | Mitsubishi WD-60735 Projection Television
I have a DLP mitsubishiWD-60735 will not power up the green light just keep flashing tried resetting the system didn't work
Replace Lamp Call Mats Electronics 1-800-628-118 or Encompass Parts for listing to all Parts for your TV 1-800-638-3328 or Go to their website.
Nov 13, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
