Question about Super Bios Chip:supermicro X9dri-ln4, X9dri-ln4f, X9scm, X9scm-f, X9scl, X9scl-f,
System initializing error BF
After changing some card it give BF error and system stuck
  • Sultan Ahmed Feb 13, 2014
    KINDLY GIVE SOME SOLUTION
BF-810 Error code 10
Windows Error Code 10 typically indicates the operating system cannot initialize or start the device in question. Usually this can be resolved by finding the appropriate drivers.
Jul 14, 2014 | BafoTech BAFO BF-810 Serial Adapter
When system boots an error occurs"system bios shadowed" "Mouse initialized error" just before the OS is loaded into RAM
Firstly I would enter the BIOS and set it to default. That should remove the BIOS Shadow. When you finally get it to boot, run CHKDSK/F to remove any hard disc virtual errors.
Hope that helps.
Mar 28, 2011 | Fujitsu LifeBookS6120 Notebook
Alarm started beeping and displayed BF check on the display screen
BF error on keypad is for Failure of Backup Communications. Usually for cell backup. If it is a monitored system, call your monitoring company. If not monitored, either call a service tech to repair it or if you have the programming code, you can turn the feature off in programming. Best to have a professional do it though.
If you have had any phone changes since it was installed, that may be a lead to where the problem is. Especially, if it is no longer monitored. BF basically means there is a problem when the system attempts to dial out to the central station on the backup setup. Again, this can be disable in programming if you no longer need it.
Jan 10, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
My nephew's original xbox will not turn on it just flashes green and orange around the power button
If your system has had an internal system error (three lights) and is now having issues recognizing controllers, remotes, and/or personal music player's, the only currently know solution is to rerun initial setup.
Rerun initial setup
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the "Initial Setup" option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup.
Resetting to factory defaults / resetting parental locks (unconfirmed)
This was posted on the xbox-scene forums and might work only with older versions of Xbox 360 dashboard.
Press the following key combination
  • Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, Up, Left Bumper, Left Bumper, X
This should give you a dialogue asking whether or not you want to reset your system to factory default settings.
Reset Xbox 360 video settings
While the Xbox 360 is starting up, hold Y and Right trigger. This will cause the system to reboot and reset the video settings.
Nov 21, 2010 | Microsoft Xbox Console
While giving print command msg comes as communication error
1. Check the cables
2. Check wheather the printer is detected?
if detected
3.Uninstall and Install the printer driver
Still facing the issuse, then you need to double check the cable
If the cable is working fine then try to do the system recovery
Sep 17, 2009 | BafoTech BAFO BF-1284 Parallel Adapter
Bios Beep code
Beep Code Manual, Better Than Gold Techies, American Megatrends Int. & Phoenix
(I'm IT, I use these codes to trouble shoot hardware issues at my job. Enjoy) cold.gif
BIOS Beep Codes
When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
The two most-used brands are AMI (American Megatrends International) and Phoenix.
Below are listed the beep codes for AMI systems, and here are the beep codes for Phoenix systems.
AMI Beep Codes
Beep Code Meaning 1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard. 2 beeps Memory parity error. The parity circuit is not working properly. 3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory. 4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard. 5 beeps Processor failure. The system CPU has failed. 6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode. 7 beeps Virtual mode exception error. 8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card. 9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty. 10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS. 11 beeps Bad cache memory. An error in the level 2 cache memory. 1 long beep, 2 short Failure in the video system. 1 long beep, 3 short A failure has been detected in memory above 64K. 1 long beep, 8 short Display test failure. Continuous beeping A problem with the memory or video. BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes. 4-Beep Codes Beep Code Meaning 1-1-1-3 Faulty CPU/motherboard. Verify real mode. 1-1-2-1 Faulty CPU/motherboard. 1-1-2-3 Faulty motherboard or one of its components. 1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values. 1-1-3-2 Faulty motherboard or one of its components. 1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers. 1-1-3-2 1-1-3-3 1-1-3-4 Failure in the first 64K of memory. 1-1-4-1 Level 2 cache error. 1-1-4-3 I/O port error. 1-2-1-1 Power management error. 1-2-1-2 1-2-1-3 Faulty motherboard or one of its components. 1-2-2-1 Keyboard controller failure. 1-2-2-3 BIOS ROM error. 1-2-3-1 System timer error. 1-2-3-3 DMA error. 1-2-4-1 IRQ controller error. 1-3-1-1 DRAM refresh error. 1-3-1-3 A20 gate failure. 1-3-2-1 Faulty motherboard or one of its components. 1-3-3-1 Extended memory error. 1-3-3-3 1-3-4-1 1-3-4-3 Error in first 1MB of system memory. 1-4-1-3 1-4-2-4 CPU error. 1-4-3-1 2-1-4-1 BIOS ROM shadow error. 1-4-3-2 1-4-3-3 Level 2 cache error. 1-4-4-1 1-4-4-2 2-1-1-1 Faulty motherboard or one of its components. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 2-1-3-2 I/O port failure. 2-1-3-1 2-1-3-3 Video system failure. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 I/O port failure. 2-1-4-3 2-2-1-1 Video card failure. 2-2-1-3 2-2-2-1 2-2-2-3 Keyboard controller failure. 2-2-3-1 IRQ error. 2-2-4-1 Error in first 1MB of system memory. 2-3-1-1 2-3-3-3 Extended memory failure. 2-3-2-1 Faulty motherboard or one of its components. 2-3-2-3 2-3-3-1 Level 2 cache error. 2-3-4-1 2-3-4-3 Motherboard or video card failure. 2-3-4-1 2-3-4-3 2-4-1-1 Motherboard or video card failure. 2-4-1-3 Faulty motherboard or one of its components. 2-4-2-1 RTC error. 2-4-2-3 Keyboard controller error. 2-4-4-1 IRQ error. 3-1-1-1 3-1-1-3 3-1-2-1 3-1-2-3 I/O port error. 3-1-3-1 3-1-3-3 Faulty motherboard or one of its components. 3-1-4-1 3-2-1-1 3-2-1-2 Floppy drive or hard drive failure. 3-2-1-3 Faulty motherboard or one of its components. 3-2-2-1 Keyboard controller error. 3-2-2-3 3-2-3-1 3-2-4-1 Faulty motherboard or one of its components. 3-2-4-3 IRQ error. 3-3-1-1 RTC error. 3-3-1-3 Key lock error. 3-3-3-3 Faulty motherboard or one of its components. 3-3-3-3 3-3-4-1 3-3-4-3 3-4-1-1 3-4-1-3 3-4-2-1 3-4-2-3 3-4-3-1 3-4-4-1 3-4-4-4 Faulty motherboard or one of its components. 4-1-1-1 Floppy drive or hard drive failure. 4-2-1-1 4-2-1-3 4-2-2-1 IRQ failure. 4-2-2-3 4-2-3-1 4-2-3-3 4-2-4-1 Faulty motherboard or one of its components. 4-2-4-3 Keyboard controller error. 4-3-1-3 4-3-1-4 4-3-2-1 4-3-2-2 4-3-3-1 4-3-4-1 4-3-4-3 Faulty motherboard or one of its components. 4-3-3-2 4-3-3-4 IRQ failure. 4-3-3-3 4-3-4-2 Floppy drive or hard drive failure. 3-Beep Codes Beep Code Meaning 1-1-2 Faulty CPU/motherboard. 1-1-3 Faulty motherboard/CMOS read-write failure. 1-1-4 Faulty BIOS/BIOS ROM checksum error. 1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard. 1-2-2 1-2-3 Faulty motherboard/DMA failure. 1-3-1 Memory refresh failure. 1-3-2 1-3-3 1-3-4 Failure in the first 64K of memory. 1-4-1 Address line failure. 1-4-2 Parity RAM failure. 1-4-3 Timer failure. 1-4-4 NMI port failure. 2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory. 3-1-1 Master DMA failure. 3-1-2 Slave DMA failure. 3-1-3 3-1-4 Interrupt controller failure. 3-2-4 Keyboard controller failure. 3-3-1 3-3-2 CMOS error. 3-3-4 Video card failure. 3-4-1 Video card failure. 4-2-1 Timer failure. 4-2-2 CMOS shutdown failure. 4-2-3 Gate A20 failure. 4-2-4 Unexpected interrupt in protected mode. 4-3-1 RAM test failure. 4-3-3 Timer failure. 4-3-4 Time of day clock failure. 4-4-1 Serial port failure. 4-4-2 Parallel port failure. 4-4-3 Math coprocessor.
Oct 19, 2008 | Computers & Internet
ERROR CODE 04C400 - WHAT TO DO, WHAT IS IT
Pulled Harddrive and ethernet card, no error. Installed hard drive started machine, no error. Installed ethernet card, restarted machine got error. I am now replacing the ethernet card to resolve issue.
Jun 23, 2008 | HP DesignJet 1050c InkJet Printer
Roll error message
hi all,
im a electronics engineer(B.E ELECTRONICS),
i was having my own repair shop (just hobby changed to repair shop)
Aiwa bmz series having mechanical problems,
it needs some timing adjustment,
i can tel clearly by seeing it.
if ur luckily staying in bangalore i can get it corrected,
u can contact me 9739317349
plese do not change any setting or gear inside,
if u did its very difficult to give life to such music system
Dec 25, 2007 | Aiwa BMZ-K1 CD Shelf System
Nokia 3230 mobile camera problem
change memory card and try with a new memory card.
Aug 25, 2007 | Nokia 3230
System file
hey ive got the FILE!! you need it?:P
Jul 31, 2007 | i-Bulldog BF-150 Digital Media Player
Super Bios Chip:supermicro X9dri-ln4, X9dri-ln4f, X9scm, X9scm-f, X9scl, X9scl-f, Logo
399 people viewed this question
Top Super Computers & Internet Experts
john h
richie46
 steve
steve
Are you a Super Computer and Internet Expert? Answer questions, earn points and help others
