Question about Kenmore 3.4 cu. ft. Compact Stackable Dryer
Kenmore laundry center
How do you pull the tub out to replace it, screw fell down in one of the holes ripping a hole in the tub.
jsrock516
  • 5911 Answers
SOURCE: worn out bellows
The bellow definitely should not deform in the manner that you describe. When you replaced the bellow, did you line it up correctly? There are alignment marks (Arrows) on the tub and the bellow to ensure it is installed correctly? If the bellow is not aligned correctly, it will twist when the tub spins. If the shocks are worn, the bellow could also deform, but you would probably experience excessive vibrating during the final spin. If you are sure the bellow is installed correctly, and wish to replace the shocks, let me know. There are four of them on your washer. I believe they are sold in pairs. If you post your complete model number (located around the door opening), I can assist you in locating parts.
Posted on Jun 20, 2008
  • 1122 Answers
SOURCE: rust
you can get appliance tochup paint at your local appliance parts store,they have many colors-mike
Posted on Nov 11, 2008
  • 15 Answers
SOURCE: washer makes holes in clothes and i want to replace the tub.
before changing the tub check if the tube and agitator moves at the same time in the agitation cicle if does probably there is problem with tansmision
Posted on Jul 09, 2009
  • 1937 Answers
SOURCE: pins that center tub on my kenmore washer fell out
The pins may just be shipping pins that are designed to break and fall into white plastic holders when the washer is installed.
See the Sears parts site for your washer at:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11092281100
to determine if these are the parts.
Posted on Sep 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: necklace stuck in holes in the washing tub.
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven’t done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o’clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o’clock position.
- With both hands gradually work your way around to the 4 and 8 o’clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
My kenmore 800 series has a problem during the spin cycle. more often than not the machine bangs all over the place. i redistribute the wet clothing multiple times so it spins in balance. but all the time....
unplug the machine,remove the two phillips screws that hold down the top console,flip up the console,with a screw driver pop the two metal clips,just stick the screw driver in the hole and on top of the clip and push back towards the wall and the clip will release,in between the clips you'll see the lid switch,a white plastic harness connector,unplug that then open the lid,grab the frame pull back and up and remove the frame of the washer,look at the bottom rear of the frame and the tub,you should see a spring hanging there,the hole that it was connected to rotted out,you need to drill a new hole and connect the spring to it,that spring keeps the machine from bouncing all around like it is
Nov 27, 2010 | Kenmore 22422 Top Load Washer
Spring came off and cannot get the top up to replace it. Series 80 washing machine top load
remove the two screws that hold down the top console,flip up the console,it's on hindges,with a screw driver pop the two metal clips,stick the screw driver in the hole and push back and the clip will release,also there's a white plastic wire harness in between the clips,that's the lid switch connection,unplug it.open the lid,grab the frame and pull back and up and remove the outside frame.if the spring fell off the back of the washer and the tub is bouncing all around,most likely the hole in the frame rotted and you'll need to drill a new hole,hope this helps,let me know how you make out
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
One of the 3 wings fell off inside dryer drum.
unplug the dryer,open the door,remove the two phillips screws that hold the door on,the screws are in the middle of the hidges,look at the other side and remove the two screws that are there,pull off the front panel grabbing it at the top where the top screws were and pull forward the bottom of panel is on clips,just slide the panel up off the clips,now spin the drum until the baffle that you need to repair is in the lower right hand corner and you can get to it there.if the holes are to big for the screws add a washer to stop the screws from falling through the holes,sometimes the screws get ripped through the holes making the holes to big for the screw heads and a washer needs to be added,let me know how you make out
May 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Pins that center tub on my kenmore washer fell out into small cups that look as though they were made to catch them. the pins look like nails with holes drilled near the point. the holes i asume are for...
Sep 10, 2009 | Kenmore Washing Machines
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
I have a Kenmore HE2 with a hole in the tub.
Any 2 part waterproof epoxy.
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
Replacement baffle installation
its a little tricky but can be done. Can you remove the top panel of your washer?? 3 screws along the back lip and the entire top will slide back and off. theres a little black hose leading from the soap dispensor to the top of the outer tub assy. its only pushed into the tub and is real flexible, pull it out .you see through the maybe 2inch hole and see he inner basket. as you rotate the basket from inside with your hand the inner baffle(s) will line up to the hole and depending on date of manufacture. they might have put a small stainless screws in from behind to hold baffle in place,ifso remve the screws and the baffle (although a little tricky should slide toward the rear of machine to remove, and pull toward the front to reinstall
Mar 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Agitated with my agitator and spin cycle
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
Apr 18, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 3.4 cu. ft. Compact Stackable Dryer Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
