Question about Toshiba DVD/ VCR RECORDER P/N: DVR18DT
FLASHING LED ON SWITCH ON - Toshiba DVD/ VCR RECORDER P/N: DVR18DT
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
TOSHIBA A300 power led flashing
Guess.
Reconnect power cable and switch on. Make sure the light to power is on then complete charging or just switch on and see if that resoves problem???
Jan 28, 2013 | Computers & Internet
FLASHING RED LED ON STAND BY
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
Aug 19, 2012 | Televison & Video
I've got flashing lights on my digitech pds 1550 distortion pedal, guitar is clean only, no matter which channel I use
the flashing led indicates the effect is in bypass. the led lights solid when the effect is on. i suggest looking for a defective bypass switch or broken wire on the bypass switch.
Aug 06, 2009 | Alert Audio Players & Recorders
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
Picture tube not working
Please provide more info.
1. Does the TV stay on, if so,
2. Is the LED flashing, how many times stop same number of times again
3. If TV goes to stanby, count the flashing LED.
4. If LED comes on goes off , at firsdt switch on. does it make a thumping noise.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
TV wont turn on?!
What type of tv is this ? If it is a GE or RCA you might have a bad flyback transformer.
Feb 22, 2008 | Televison & Video
3com 3300 TM - all Ethernet port not working, power led flashing
A blinking power LED means that the switch is either downloading software, or is initializing which also includes running the Power On Self Test. You may have firmware issues with the switch and/or the switch is stuck in initialization mode. You may have to contact 3com regarding a warranty issue. Hope this helps. Good luck.
Nov 20, 2006 | 3Com SuperStack 3 3300 TM Networking...
Toshiba DVD/ VCR RECORDER P/N: DVR18DT Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
