Sharp copier ar5316e output is black - Office Equipment & Supplies
    New Friend:
  • 3 Answers
Your ar-5316e machines toner & developer both are bad so you change your toner & developer & use original toner & developer
Posted on Feb 17, 2014
  • 208 Answers
SOURCE: MY SHARP AR5316 DISPLAY H4 WHEN I PUT IT ON
Here is the process
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 14, 2007
sir fixalot
  • 146 Answers
SOURCE: add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Posted on Jan 02, 2008
  • 2072 Answers
SOURCE: sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
If this does not clear the problem the fuser will need replaced.
Posted on Feb 21, 2008
  • 7 Answers
SOURCE: SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
Posted on Mar 23, 2009
  • 74 Answers
SOURCE: error f2 in sharp copier AR5316E
F2 sub code 00 - Toner Sensor problem, ID pattern reading error. You may have to replace the drum unit or have a tech clean the toner sensor
Posted on Mar 31, 2010
I want the drivers for Sharp AR-5320
http://support.sharp.net.au/drivers/, GO TO THIS LINK, CLICK PHOTO COPIERS AND DOWNLOAD AR5316. RATE THIS AND VOTE FOR THIS
Apr 05, 2011 | Sharp AR-5320 Black and White Copier
I can not set up my system with windows seven 7 please send softwere for my syetems . my sestem is sharp AR5316E
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Select
Photocopiers > AR5316E > Windows 7 (32-Bit OR 64-Bit)
Hope it helps! Good Luck!
CreativeTECH
Sep 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
Am having problem with my copier machine
When this copier TD unite is out of life or not connect properly then show this signal.
Solve: # interrupt C interrupt press 16 then solve it.
Mar 31, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5320
This may help you.
http://www.2shared.com/file/11139038/ef25b451/AR5316-5320_SM_dif.html
Dec 16, 2009 | Sharp AR-5320 Black and White Copier
AR5316E error code h2
hi in put # + inroput + c + intrupt + 14 + start
Mar 07, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | Sharp AR-5320 Black and White Copier
15 people viewed this question
k24674
jasbo
jasbo
