Question about Xerox WorkCentre 4150 All-In-One Laser Printer
Unable to connect to remote server - Xerox WorkCentre 4150 All-In-One Laser Printer
I am able to connect 80.0.75.60 server remotely ..in that i need to connect to one of my application server 80.0.75.62. i am unable to connect. actually servers are in sum other place. while pinging to...
The gateway at the remote end may be down. Ensure that the remote gateway runs fine. See whether the application server (80.0.75.62) has communication with remote gateway.
Sep 27, 2010 | D-Link DFL-800 Firewall
Unable to ping static IP from remote desktop when
Does PING works on the same location where Camera's are located?
Usually, RDP connections uses the same PC on LAN and that should work fine. Please check Camera's configuration; make sure they have valid IP address, SM, Default gateway and DNS servers. Make sure that PC with enabled RDP can PING computers on the LAN either by IP address or Computer name. Make sure they're part of the same WORK GROUP.
Hope this helps! Please provide additional information so I can further assist you.
Mar 28, 2010 | D-Link DI 514 Wireless Router (DI-514)
Unable to connect to Norton or other antivirus provider
Try avgfree.com I have found norton to be a pain in the a*** at the best of times, or even atwil.com and download avast free security suite both very good and free.
Aug 23, 2009 | ASUS Eee PC 1000HA Notebook
We recently experienced a power outage and unable to log ont
In most cases you just have to reset your modem and/or router, to do this just unplug the modem for the mains for 2 minutes, plug it back in and wait another 2 minutes for it to settle down, then you can try to reconnect to the server.
Regards.
Jul 14, 2009 | Microsoft Windows Server Standard 2003 for...
Unable To Connect With Remot Server
Surfing uses a different gateway than data. Do you have a data plan or is cellular data turned off on your handset? To check this, press the power button, select Wireless Manager, go to phone and select Menu softkey and see if cellular data is on.
May 31, 2008 | Samsung Blackjack SGH-I607 Smartphone
RPC Service not running
Please restart the service of RPC.
Write the script for RPC services by the help of google ur problem will be shortout .
Regards
MAYANK GUPTA
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Mirc V6.2
Please try connect to another server as "/server irc.dal.net" or "/server irc.efnet.net"
hope this can solve your problem
Mar 21, 2008 | Computers & Internet
Error: "You may be able to send mail but not receive it. Unable to access your remote folder on the network"
Microsoft provides a patch that will need to be applied to the Exchange Server. This patch can be found at ftp://ftp.microsoft.com/bussys/winnt/winnt-public/fixes/usa/nt40/hotfixes-postSP4/Rnr-fix/rnr-fixi.exe. The server will need to be rebooted. The end user should then be able to connect using the IMAP4 client.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Xerox WorkCentre  4150 All-In-One Laser Printer Logo
53 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
