Question about Sony Televison & Video
Sony wega e60 tv , want to take apart and clean inside
3 Suggested Answers
  • 1527 Answers
SOURCE: replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
Posted on Nov 10, 2009
chesterpendi
  • 195 Answers
SOURCE: how do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking li
Good day!!!
6 blinks its the clear indication that you have bad power supply board..
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Dec 07, 2011
Dark smudges/spots on my HDTV screen
The model indicated here Sony Grand WEGA KDF-50WE655 is a LCD rear projection and rarely if ever requires cleaning.
If black spots or such are gradually appearing the issue on this model is the optical light engine.
Set uses a LCD engine which the lamp shines directly into and heat from that very hot lamp can damage sensitive baffles inside the engine.
I would suggest also you contact Sony as they have on several models extended the warranty for this kind of issue---Engine is very expensive part and several of these Sony sets were involved in a class action lawsuit--hence they are dealing with them.
Do not take no for an answer if you want them to help you---the hinge that is sqeeks gets oiled...........
Apr 02, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Wega television has a red light flashing that says lamp
When Sony tv shows lamp light that means lamp inside tv is dead/ broken and need to be replaced.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony wega kdf-60xbr950 tv does not turn on, it just make clicking sounds. I order a new lamp assembly and it did not fix the problem.
The projector inside the unit can become clogged with dust in its cooling fans which causes load and shut down of the unit. If you feel comfortable take the back off get a really long phillips screwdrivers and remove it, take it apart and clean the dust out.
Apr 29, 2010 | Televison & Video
6 blinking red lights
You still have your guessed problem. 6 blinks means Low B+ error (power supply). This can be caused by an open thermal fuse, loading by another circuit board, or the power supply itself.
Apr 13, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a slight yellowing in the center of my screen. We recently replaced the map, and have tried adjusting all picture settings but the yellow patch remains. It's a Sony Grand Wega, by the way.
Don't know if the DLP tvs have a Deguassing coil,inside it bazel frame.Take ur tv aparts check,see if u have big coil rapping with ectrical tapes fit inside ur bazel frame of ur tv.If yes,the componnents parts that make the coil work it dead.This coil demagnictize for the tv tube first turn.All regular small CRT tube tvs '30 inches and down have this dequassing coil inside it bazel frame.
Apr 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
Jul 01, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Have sony 36 trinitron about 5 years or older..the picture just shakes. never lose the picture or the sound. just cant get it to stop shaking.
U have magnatic degausing coil problem.Take the tv aparts,there a solid back coil all around inside the front frame of ur tv.That the cause,unplug that coil,should not effect the tv pic if have no magnatics problems.
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Cleaning Optical Block
Sorry to be teh bearer of bad news, but the optical block (light engine) can not be dis-asembled outside of a cleanroom. You can remove the rear cover of the set and clean the mirrors and glass. That may help, but usually these typesd of symptoms are an indication that the light engine is starting to fail. The light engine can be replaced by you if you feel comfortable. The part is still available.
Keep us posted.
Dan
Aug 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Model KF-42WE610
Major job to disassemble this unit to clean it. I recommend a qualified Sony tech to do this. With great care and a very sharp ended blade the from protective shield can be cut off, but the Sony two sided tape is no longer available. So it should only be done by complete disassembly.
Feb 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony tv kv-29F1U
tuner needs replaced or taken apart and cross your fingers soldering joints, use silver solder look hard with magifiers for solder cracks or bad joints and grounds inside tuner.
Jan 18, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
14 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
