Question about Bates Numbering Machine RNM6-7
How to put ink on my bates royall stamp rnm6-7?
How do i put ink on the stamp
ROYAL DOULTON ANTIQUE PLATES
sorry but we are not in the antique business .
May 21, 2015 | Royal Doulton Carmina Dinnerware...
How do I put ink in for IDEAL300?
  • Push stamp down slightly and push buttons on side to lock into position (Image 1).
  • Push button and then pull out ink pad (Image 2). For other style Trodats, just push the ink pad (there will not be a button).
  • Put 10 - 20 drops of Ideal Ink on the inked side of the pad.
  • Once the ink has absorbed into the pad, push the pad back in (Image 3).
Jan 09, 2012 | IDEAL 300 Custom Rubber Stamp - Black Ink
How can you bates stamp with a konica minolta bizhub?
What model bizhub do you have? Konica Minolta bizhubs do not Bates stamp as a standard feature. If your bizhub is compatible, eCopy Sharescan can provide Bates stamping numbering. This is an accessory you would need to purchase. If you post the model, I would be happy to confirm that it is eCopy capable.
Jun 18, 2010 | Konica Minolta Office Equipment & Supplies
How do i set my Rogers 04213 automatic numbering machine to change numbers sequentially instead of randomly as it is currently doing?
I suspect the wheels are sticking together, a common problem from dried ink, or there is a burr or cotton fibber between the wheels. It may be a case of the wrong ink but clean it first. Use a combination of two wooden sticks... most anything will do to hold one wheel while you manually turn the other. Retract the ink pad and lock it back using the catch on the shaft. Use q-tips saturated with kerosean to disolve the ink and lubricate the wheels. If need be you can use a paint scrapper or slim knife to help to spread the space between the wheels after you have let the kerosean do its work. Caution take care to protect your eyes from a snapped blade. It shouldn't take very much force to wedge the wheels apart. If there isnt space on one side rotate the wheels 180 degrees to the other. Although you don't want the kerosean on the ink pad it won't damage anything. You'll want to wipe off, squeeze of, spin off, stamp off as much as possible. as much as possible before you re-ink your pad. Order yourself some Bates numbering machine ink. Take the time to mix it well. My preference is blue if you can get it.
I read where some one had problems with their screws loosening. I never had that problem with this model but if I did I would clean the screws and holes with acetone or solvent quality alcohol and tighten the screws back in with lock tite.
I like to stamp my documents before I scan the for search indexing and he like.
Sep 30, 2009 | Office Equipment & Supplies
Verification stamp
If the old one is still there you can get stamp ink from Staples and put ONE drop of the ink on the stamp and blot with a kleenex.
Sep 03, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Bates Numbering Machine RNM6-7 Logo
112 people viewed this question
Top Bates Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Bates Office Equipment and Supply Expert? Answer questions, earn points and help others
